Question about Dishwashers
Kitchen aid NOT CLEANSING DISHES
DISHES NOT CLEAN... SOAP LEFT IN DISPENSER.... JUST NOT FUNCITONING PROPERLY
  • 126 Answers
It sounds like you are not getting enough water to make the dishwasher function effectively. Could be a bad valve could even be that the spray arms aren't letting through enough water.
Posted on Jan 02, 2009
There is residue left on dishes after wshing and a whitish film on the dishwasher door. Looks like mineral deposits. My rinse aid dispenser has stopped working as well. Could this possibly be solved by...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101';;'';
Apr 03, 2011 | KitchenAid 24 in. KUDS25 Built-in...
Miele dishwasher G 1232 sc no longer dries
the problem with not drying is normally three things
1. not adding enough rinse aid to the compartment (dispenser) and adding to much soap.
ex rinse aid helps with drying,spots and cleanind the dishes. so if is none then you want get maximum cleaning.
3. make sure you run the faucet to get the hottest waster going into the machine this will make the other two do it job better because as you know you cant clean dishes properly in cold water.if this info helped please send me 4 thumbs post , thanks
Mar 01, 2010 | Dishwashers
Soap does not disolve and residue left on all
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 17, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishes dont get washed soap left on door something not right
Soundl like you're not getting water going into the dishwasher. Check out the water inlet valve.
Nov 19, 2009 | Whirlpool Dishwashers
The some dispenser and the rinse aid dispenser seem to be "stuck", soap door doesnt open and dishes appear streaky from no rinse aid. this happened after I cleaned the deposits from under the screen in the...
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Oct 21, 2009 | Bosch Dishwashers
Kitchenaid KUDP01 not cleaning dishes
Remove the accumulator assembly and check the chopper to see whether it's clogged or damaged.
Jul 02, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher does not rinse clean
run the dishwasher empty: use 1/2 the amount of soap you usually use in the soap dispenser close it then put white vinegar in the open dispenser and, run the dishwasher
Apr 22, 2009 | Dishwashers
DISHWASHER NOT CLEANSING PROPERLY
there is a food shreder located in the pump at the impeller intake, it looks like a round screen with a rotating blade on it, if the blade breaks off then the screen gets cloged and will restrict water flow.
Jan 01, 2009 | Dishwashers
Dishwashers Logo
114 people viewed this question
Top Dishwashers Experts
