Question about Dell Dimension 9100 PC Desktop
Cross-referencing databases I have two databases of members in two different organizations. Is there any way that I can cross-reference the two databases so that one list will show only the names which appear in both databases?
  • 39 Answers
This should be relatively easy, just create a query that has an equijoin on the name fields. If you're worried about misspellings, you could match on a soundex of the names.
Posted on Feb 09, 2009
What is torque bolt setting on 1995 infiniti cross member
Probably not specified anywhere, but most shop manuals or mechanics data books will have a chart of usual torque values for bolts of different grades and sizes. If it were mine, I would replace any lock washers, use a good ratchet or 1/2" breaker bar and snug them to about 25 to 35 ft. lbs.
Jun 02, 2015 | Infiniti Cars & Trucks
Is the cross member under the load
cross members are the chassis members that tie the side frame rails together. There will be one at the front and another at the centre of the chassis and one at the rear . There is a bolt in cross member at the rear of the gear box (rear engine mount). Most modern cars are uni-construction (that is the body is complete and the front section will have a front cross member and the sub-frame rails will be bolted under the body around the front door pillars and onto the fire wall.. IN heavy vehicles there is a front cross member the carries the front engine mount another after the gear box to carry the cabin mounts and then a member every 3-4 feet to the end of the chassis rails . Their only purpose is to tie the chassis rails together.
May 03, 2014 | 1989 Chevrolet G20
1994 gmc sierra 1500 pickup 4.3 L. v6...I am dropping trans pan to replace filter and gasket and add fresh trans fluid....the rear pan bolts are obstructed by a cross member and trans mount....I can see...
What you do is loosen or remove the cross member first
Then you decide,if using a small air driven cut off wheel to
remove some metal from cross member,will help remove
the trans pan in the future.
Apr 22, 2011 | GMC Sierra 1500 Cars & Trucks
Hello, ok I got a 95 Yukon 4 door, now with the four door they have the dog bone insulators. The 2 door has cross member right to the frame. I recently got into an accident smacked a curb with the...
Yep, Sounds like you have a bad misalignment that is causing stressing of the suspension. This also may cause another accident or cause injury. Have a body shop give you an estimate to repair the damage. They may tell you what is not right. If the cross member is obviously bent, they may be able to straighten it. If you are confident you can fix it, measure a good one, same model. take pics with your cell phone. Get all the frame mounting points as close to factory as possible using a solid good original point as a reference. Also check the top components are probably bent as well. Harbor Freight sells a hydraulic ram kit that may help. be very careful and should only try this is you are very handy, very safe, and a general fabricator.
Apr 03, 2017 | 1995 GMC Yukon
I have a 1976 dodge van with a 360 . would like to no what year dodge tranny with overdrive will fit my 1976 van
http://www.upullandpay.com/Cross-Referencing.aspx
you need a cross reference for auto parts..
try this site, it may help..i just found it after a quick google search.
hope this helps, or puts u on the right track
Jan 09, 2011 | 1983 Dodge Pickup
I just rebuilt the transmission in my 1999 Dodge Durango. Getting the trans mount cross member out was a chore but now it seem that the cross member is about 1.5 " longer than it was when I took it out. ...
The frame rails move in when you remove the crossmember. I put a port a power between the frame rails to remove and install the crossmembers on dodge trucks.
Sep 23, 2010 | 1999 Dodge Durango
Knocking coming from under the extended cab from
There called torsion bar mount bushings, and will cost about $34.00 for both of them. Parts Source.
Jack up RH side of truck, crawl under LH side
  • 1 Remove nut from torsion bar mount stud that secures the mount to the cross-member. You'll have to feel for it, you won't be able to see it from below.
  • 2 Remove bottom two bolts. Easy, they're in plain view from below. Now the mount is free.
  • 3 Push up on cross member, remove old mount.
  • 4 Insert new mount - push up on cross member, slip mount in between frame and cross member. Drop hole in cross member over the stud.
  • 5 Loose assemble nut and two bolts. Torque down once other side is done.
Now over to the passenger side
  • 6 Jack up driver side of truck
  • 7 Repeat steps 1 and 2
  • 8 To get the mount out, try pushing up on the cross member, just like the driver side. If it comes out, great. I couldn't get the cross member up high enough on mine. I used a big screwdriver and ripped it out by separating the rubber from the metal plate. It came out in pieces.
  • 9 Install new mount. If you didn't have trouble getting the old one out, you probably won't have a problem getting the new one in. As I said, I did. I couldn't raise the cross member high enough to slip it in. Solution: whack 3/8" off the stud. You'll still have plenty left for the nut.
  • 10 Reinstall nut & bolts, torque down.
  • 11 Remove jack, Torque down drives side.
Good luck. The TRW's are one-piece urethane, (I think) and came with a lifetime guarantee. They'll probably outlast the vehicle.
Nov 15, 2009 | 1993 Chevrolet S-10
Cross Reference part
The original transistor for the Horizontal output is a 2SC5588 you can get an original at the following link.
http://servicemanuals.vstore.ca/
Feb 01, 2009 | RCA D52W19 52" Rear Projection Television
CLUNKING NOISE FROM REAR AXLE
Problem I found: Clunk when driving over even small bumps.
If Grand Cherokee is 1999-2004, then check this: Above the differential is a wishbone cross member control arm. The cross member attaches to the frame in front of the rear axle (bolts through rubber bushings), and directly above the differential, at the apex of the cross member, is a ball joint. The ball joint assembly is a flange bolted atop the differential, with three bolts, and the ball joint pin protrudes from the flange through the cross member apex, with a nut atop the pin. Raise the frame slightly, and with a pry bar, pry above the flange, and below the cross member, very near the ball joint. If any motion is detected, then the ball joint is worn from the ball joint socket, or the nut is loose on the ball joint pin. If the nut is tight, then replace the ball joint. 2000 GC part number is 52088808AB, and is available from online sources or dealers. To replace this part, you'll probably need to remove the cross member, as the ball joint pin through the cross member is in a tight location, is tightly wedged into the cross member, and requires a special v-shaped puller to remove the pin from the cross member. If you don't have access to the puller tool, then remove the cross member for this operation. Raise vehicle slightly, under frame, in front of rear wheels. Unbolt the brake line and brake cable retainers from the cross member, then unbolt the flange from atop the differential. Then remove the two frame bolts and manipulate the cross member out of the vehicle, from above the differential.
With the cross member before you, support on blocks, loosen the ball joint nut somewhat, or remove it, and with a beater protective block, sledge out the pin from the cross member. Inspect the rubber bushings at this time. These bushings require an arbor press to remove/install, and the arbor press to install requires a spider so as to not rip the rubber bushing from either the bushing shell or center spool. The press spider is a 4-point tool you can make up from a piece of aluminum.
Bolt the new ball joint flange atop the differential, using blue thread locker, and torque the bolts to 100 ft-lb, cheater pipe useful here.
Replace the cross member to the frame, and install the two frame bolts, finger tight. Pull the member apex down onto the ball joint pin, and run the nut down. Using a box end wrench, hold the pin from rotation while tightening down the nut. Torque the nut to 100 ft-lb. Tighten the frame attachment bolts to 100 ft-lb, and reinstall the brake cable and brake line retainers. Do not over tighten these retainer bolts, as they are passing only through the sheet steel side of the cross member. Take care to not strip the sheet metal threadings. Lower vehicle and remove jack.
May 15, 2008 | 2000 Jeep Cherokee
Dell Dimension 9100 PC Desktop Logo
52 people viewed this question
Alun Cox
