Question about HP OfficeJet D135 All-In-One InkJet Printer
HP D135 printed lines are angled slightly downwards left-to-right
Just recently, I noticed that the printed lines are no longer perpendicular to the paper side. The printed lines drift downwards a bit as if the print head is moving across the paper while the paper is moving before the printed line is completed. Tried alignment diagnostics etc with no luck. It's not worth a repair charge and am hoping for something I can correct myself.
Thanks
  • twobells Jan 01, 2009
    Went to HP support website and will clean the 4 rollers as suggested. Will let you know if it helps.
Twobells i have almost the same problem with the hp photosmart c4599 i have had no luck either
Posted on Jan 01, 2009
What is the meaning of perpendicular lines
Parallel lines are lines that go on forever and never cross. In mathematics terms, they have the same slope, but different y-intercepts. For example, y= 3x + 5 and y=3x +7 are parallel lines.
Perpendicular lines are lines that intersect each other at 90 degrees or at right angles. If y=5 and we are looking for a line that intersects it at 90 degrees (or right angles), the line would be x= 4.
Another example would be y = x. The perpendicular line would be y = -x.
To find the perpendicular line, the slope will be the negative reciprocal. For example, y = 3x + 5, the line perpendicular would be y = - 1/3 x + b.
Another way of looking at this is if you take the slopes of the two line and multiply them, you should get -1.
Let me know if you have any questions.
Good luck.
Paul
Jan 26, 2016 | Office Equipment & Supplies
Draw a perpendicular bisector
It is a line that meets the first line at right angles (90 degrees, perpendicular) and cuts that first line exactly in half (bisect = to cut into 2 equal parts)
Sep 04, 2014 | Computers & Internet
What are perpendicular lines
Two lines are perpendicular if they belong to the same plane and intersect (cut) one another at right angle. They make a 90 degree angle. If you are doing analytic geometry, two lines are perpendicular if the product of their slopes ia equal to -1.
Other relative positions of lines are parallel (they have the same slope/direction) or they are just secant at an angle not equal to 90 degrees.
Feb 03, 2012 | Office Equipment & Supplies
How do i change the cartridge
See below: Also is a link the the manual for your unit the maunal has pictures: Page 62 of the manual list the procedure. (page 72 in the adobe file)
Manual
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
Note: It is normal to see ink buildup in the print cartridge slots.
Print-carriage
access door
hp officejet 5500 series
chapter 8
64 maintain your hp officejet
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the pink tape by using the pull
tab.
Caution! Do not touch the copper contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge
immediately to prevent the ink from drying in the nozzles.
4 Hold the black print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into the slot.
It must slide in at a slight angle.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
Note: You must install both print cartridges in order for your HP Officejet to
work.
reference guide
65
6 Close the print-carriage access door. Within a few minutes, a print
cartridge alignment page prints.
Feb 25, 2011 | HP Officejet 5510 All-In-One Thermal...
I have an hp officejet d135. It has knew ink jets and is hooked up. When I try to print the ink won't come out and the window says it's empty. Do I have a toner and if so where is it?
Your printer has a print head under the ink cartridges. You can try a cleaning, and if this does not fix the issue, you may need to replace the print head .
Clean Printheads function
To activate the Clean Printheads function from the front panel:
  1. From the front panel, press MENU.
  2. Press the RIGHT or LEFT ARROW until Status and Maintenance displays.
  3. Press ENTER
  4. Press the RIGHT or LEFT ARROW until Clean Printheads displays.
  5. Press ENTER
After a few minutes the HP Officejet D series will automatically complete the printhead cleaning operation.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 24, 2011 | HP OfficeJet D135 All-In-One InkJet...
How do I put new cartridge in
Follow this procedure to install print cartridges in you printer.
touch only the black plastic, gently remove the tape by using the pink pull tab.
Caution! Do not touch the gold-colored contacts or ink nozzles.
4 Hold the black or photo print cartridge with the HP label on top. Slide the print cartridge at a slight angle up into the right side of the print carriage.
It must slide in at a upward slight angle.
It must slide in at a slight upward angle.
Note: You must install both print cartridges in order for your HP Officejet to work.
“Press OK to print Align page” appears on the display.
7 Press OK.
Oct 06, 2009 | HP OfficeJet 4215 All-In-One InkJet...
HP D135 PRINT error
I am sorry the print head goes out on the B And W on these things quite frequently. however you can go to www.hp.com amd go threw thier secdualed way of testing the print head but am sure you will find it defective. I had one and it was a problem. B e aware they have a new head that replaces the old head that lasts much longer.
Oct 05, 2009 | HP OfficeJet D135 All-In-One InkJet...
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Prints magenta line slightly off center on everything
Try a printer calibration.
If this doesn't work than comment again. I have one of these printers at work and I can do more to help tomorrow.
Oct 16, 2007 | HP Color LaserJet 2600n Printer
HP OfficeJet D135 All-In-One InkJet Printer Logo
51 people viewed this question
Ben Johnson
