Question about Samsung RS2630WW Side by Side Refrigerator
Fridge temp too high
The display is saying the fridge temperature is 16. We have tried to lower it and it flashes 3 - the temperature we want it to be. But then goes back to 16. Over night it lowered to 14 and having left it for a day it has now gone down to 11. There seems to be no quick soloution. The top of the fridge is hot and food is not being chilled enough. Food at the bottome seems to be chilled enough. The deodorizer light and twin cooling have now come on even though we did not put them on. Any ideas?
  • 1 more comment
  • Claire Smith May 10, 2007
    Your a genius. Thank you!
  • Anonymous Apr 23, 2008
    Temnp control is flashing 1, however thr fridge is warm and food not chilled. I have pressed the Fridge temp button but it still flashes.
  • G Harvey
    G Harvey Dec 30, 2013
    I just had the same problem. The cooling coils are frozen over. Unplug the fridge. Empty the freezer and/or fidge. Remove the plastic panels inside at the back. I used a hair dryer to melt the ice. Dont force the panels as they have styrofoam on the back and might be frozen to the coils. Use towel to soak up water from melting ice in bottom. Once ice is TOTALLY melted from coils, then I took that opportunity to clean, since everything was warm. Replace panels and plug in. Start with temp at highest setting first. Then once it reaches that, let fridge set for a few minutes, then lower temp. That way the compressor isn't being strained all at once. DONT use power freeze or power cool during the time of first use after this procedure. On fridge side, you will need to unplug 2 connectors. They will only go one way, so reconnection is simple. This process will take 2 hours with removal & replacement of panels and melting of the ice per side. Just unplugging it and waiting for ice to melt would probably take over 2 days. Ours now works like it should.This whole problem was caused by a small toy in the freezer holding the ice maker flap open and letting way too much humidity into the freezer, which made it work too much.
    President:
  • 1,462 Answers
Probable cause is jammed fan. first take back panel off fridge, electrical connections are plug and socket. yoy may find a quite small build up of ice underneath the fan. melt it off and you should be ok. samsung are prone to this problem
Posted on May 08, 2007
How can I reduce my fridge temerature on my HRF370SS FRIDGE FREEZER, IT KEEP GOING HIGHER 9- 14
If this is tight against the back wall and even side, pull it out some so it can breath... When a fridge is tight against the wall it can't breath with Air and works harder hench a colder temp.... Try pulling it out.. UNplug for 10 mins.. Lower the temp dial.. Plug back in. Also if you have pets make sure not PST hair is clogged underneath the unit..
Sep 03, 2016 | Haier Refrigerators
Difficult fault on samsung side by side fridge freezer SRS615DP
the problem must have been solved by the replacement of board..
i think you must consult the mechanic again for this
Aug 19, 2008 | Refrigerators
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Mar 23, 2014 | Frigidaire Refrigerators
Electrolux fridge temperature control displays a "square"
Try lower either the thermostat setting or the airflow control to the refrigerator to see if the temps are lowered.
Nov 26, 2013 | Electrolux Frigidaire Fridge Defrost Timer...
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Samsung side by side
you can reset the fridge by pushing "Power Freeze" and "Power cool" at the same time
it worked with my fridge Samsung RS21DAMS which stopped after a power cut and was also flashing at the digit of the fridge temp display
Mar 28, 2008 | Refrigerators
FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Jan 05, 2008 | Refrigerators
Samsung RS2630WW Side by Side Refrigerator Logo
940 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
