Question about Emerson HDC12 Humidifier
Cf diplayed after filter change,how to stop CF?
CF extinguish?
The CF comes on after 720 hours of operation (while continuously plugged in). Really stands for Check FIlter, not Change FIlter.
Just pull the plug and let is stay unplugged for 30 seconds or so. When you plug it back in, it will be reset for another 720 hours.
Gene
Posted on Feb 13, 2010
I have an essick humidifier and it keeps flashing CF but it continues to run. What does the CF mean.
Check Filter Indicator The ability of any humidifier to efficiently supply humidity output relies heavily on the condition of the filter. As the filter loads with impurities it gradually loses its wicking capability. When this happens, moisture output is reduced and the humidifier has to work longer to satisfy the selected setting. This humidifier has a check filter reminder timed to appear after 720 hours of operation. When the Check Filter (CF) message is displayed, disconnect the power cord and check the condition of the filter. If a build-up of deposits or severe discoloration is evident replace the filter to restore maximum efficiency. The CF message is reset when the humidifier is plugged back in.
Dec 03, 2017 | Humidifiers
My Kenmore Humidifier 15420 has a code of "cf" what does it mean?
Depending on your model, the CF could mean the filter needs to be changed or that the unit needs to be reset. If your model doesn't have a reset button, you can unplug the unit from the outlet for 5 minutes.
Jan 18, 2017 | Kenmore Humidifiers
How do you reset the cf on essick humidifier
I just changed the filter and it started flashing CF. How do you reset this other than changing the filter?
Feb 04, 2013 | Essick Air Humidifiers
Have a MA0800, have changed the filter but can't clear the flashing CF display.
You have to unplug the unit from the electrical outlet. Just shutting it off won't clear the CF code.
Jan 12, 2013 | Essick Air MA0800 Humidifier
Humidifier what does CF stand for
It may mean "Change Filter." After you replace the filter, unplug the humidifier for 30 seconds, and then you plug it back in, the CF code should be gone.
Dec 04, 2011 | Kenmore 14410 Humidifier
I have the MA0800 and I have a CF flashing on the display. How do I get rid of this code? If it requires a clean filter, then how do I reset this code once I have a clean filter?
Change the filter then unplug the unit from the electrical outlet and the code will be cleared. Just shutting the humidifier off won't clear the code, it has to be unplugged from the power to clear the flashing CF.
Jan 21, 2011 | Essick Air MA0800 Humidifier
What does the cf stand for
Found the answer in the original manual. CF means check filter, this displays every 7200 hours of operation. If the filter is OK just unplug the unit for 2 minutes and the display will reset.
Dec 26, 2010 | Essick Air Humidifiers
I have lost my manual. readout on the digital display is CF. humidifier operates fine. what does the display CF mean?jiml@suddenlink.net
It means Change Filter.
However, assuming that you have done that in the recent past, you probably want to know more. I'm not sure how this actually works (that is why it shows CF). I saw it for the first time after 2 or 3 years of using my humidifier. (And I had just changed the filter a week or so previously).
You may have to turn the unit off/on or even unplug it to clear the message, then it should operate normally.
Nov 05, 2010 | Emerson HDC12 Humidifier
Kenmore 15408 Humidifier How to Reset CF
Per the owner's manual, you simply unplug your device for 30 seconds. Upon plugging it back in, the CF notification should be cleared.
This assumes you have also changed the filter, of course.
Feb 08, 2008 | Kenmore 14410 Humidifier
Emerson HDC12 Humidifier Logo
1,669 people viewed this question
Top Emerson Humidifiers Experts
Paul Carew
Dennis
Are you an Emerson Humidifier Expert? Answer questions, earn points and help others
