Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Chainsaw floods out after about 10 mins
Chainsaw floods out if you leave it sit for ten to twenty mins it starts agin and runs for ten more
  • jcsaws May 11, 2010
    so it run fo 10 mins? than floods.
    So are you saying it gets to much fuel than stops. ?
    If so is s/plug wet with fuel,or just stops
  • Anonymous Mar 18, 2014
    starts when cold without priming, if primed will flood and refuse to start
  • 181 Answers
Sounds to me that the needle in the carburator is bad.you need to rebuild the carb. and check the settings when your done
Posted on Jan 07, 2009
SOURCE:
What would cause a poulan chain saw to quit running after about ten minutes of cutting
The only temperature sensitive part I can think of is the condenser. In most saws it is under the flywheel with the points. Some newer saws have an electronic ignition module. If that is the case the module must be replaced.
Oct 15, 2014 | Poulan Garden
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
Chainsaw will not start. might be flooded. only fairly new.
If the saw is flooded, remove the spark plug, switch the ignition off, push the choke in, now crank the engine approx ten times, now leave the saw for an hour, re fit the plug and try to re start the saw not useing the choke. Dont forget to switch the ignition back on.
Feb 10, 2011 | Garden
When you go to start the car it will start and die then if you go to start it agin it will turn over and will not start like it is flooded then if you let it sit for about 15 min it will start. I have...
Check the fuel pressure to the fuel injectors to see if it is within specs.
Also, check that the fuel injectors are not worn out or leaking causing a flood condition.
Jan 02, 2011 | 2002 Pontiac Grand Prix
How to start a Husqvarna 445?
Set choke to full on. To do this depress throttle all the way down and set choke lever to on. Pull starter rapidly until saw fires . Once it has fired set to start and pull starter cord until it starts. If it doesn't start in ten - twelve pulls,reset choke for two or three pulls,then switch back to start. Pull starter cord until it starts. When it starts it wii be at full R.P.Ms. Let run for twenty to thirty seconds. then move switch to run. Hope his helps, Thanks
Nov 18, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
1999 Pontiac Sunfire ignition lock cylinder changed but car has anti theft and car wont start. How can I get it to start?
try turning the ignition on try to start then without shutting key off wait 10 mins then shut key off then back on but do not try starting leave on for ten mins then back off turn key back on to run but do not try starting it wait ten mins then if it reset it should crank over and start if not repeat all steps again
Sep 19, 2009 | 1999 Pontiac Sunfire
Runs about thirty miles then acts like flooded or exhaust plugged
try checking your cadlist convert on your exhusted
Dec 26, 2008 | 1996 Dodge Caravan
1989 BMW 735i Hot start issue
You might want to try replacing your throttle return spring, or at least lift the hood and see if here is a change while it smooths out..
May 23, 2008 | BMW 750 Cars & Trucks
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
278 people viewed this question
Top Poulan Garden Experts
roeb
Jay Finke
Jay Finke
dannydoesita
Are you a Poulan Garden Expert? Answer questions, earn points and help others
