Question about Dishwashers
Reset antiflood E1 fault on Smeg dishwasher DW1612C
The dishwasher is not flooded and I can't get past this fault
5 Suggested Answers
COXY
  • 76 Answers
SOURCE: SMEG INTEGRATED DISHWASHER FLOODING
Are you saying it overfilled and flooded out, or did it empty onto the floor?
Posted on Nov 18, 2007
SOURCE: Dishwasher Smeg DWD409SS
Hi
Please go to www.smeg-service.co.uk/support
Posted on Aug 21, 2008
SOURCE: anti flooding system
yes I will for $14.99 !
Posted on Aug 28, 2008
  • 1462 Answers
SOURCE: E2 error in smeg dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
Posted on Nov 20, 2008
SOURCE: e1 fault no manual
Hi, use this table to find and know more about codes.When you get into the link,scroll you will see all codes and solution.
(repairclinic.com/0078.asp).
Take care.
Posted on Jun 14, 2010
Smeg D1 612 CA dishwasher wont run
You may have to give a little more information.
Have a look at the manual, here -
http://www.manualslib.com/manual/343502/Smeg-Di612ca.html
and check for error codes/lights etc (p17; faults E1-E9)
Hope this helps
Oct 28, 2013 | Smeg Dishwashers
Smeg e01 error
E1 error code is an antiflood error code.
Water will be in the base of the washer due to a leak. So what you need to do is pull the washer out and tip it 45 degs backwards and the water will drain out from the base. so you may need a towel for that part.
Once the water is out the antiflood switch will reset itself and the washer should start to work again from there.
Then just keep an eye on it and see if you can locate the leak if there is 1.
Regards
Read more: We have a Smeg WMF 16 AX washing machine with E 01 fault code. - JustAnswer http://www.justanswer.com/uk-appliance/5d0im-smeg-wmf-16-ax-washing-machine-01-fault-code.html#ixzz2DA8T3rGE
Nov 24, 2012 | Dishwashers
Error code 1
Contact a qualified appliance technician if you see an E1 error. An E1 error appears when the anti-flooding system has been activated
God bless you.
Sep 27, 2012 | Smeg Dishwashers
Newish Zanussi ZDF 511 dishwasher fills the antiflood device
If you cannot find a leak then check that if you are using the 4 or 5 in one tablets that you are not using rinse aid seperately as this is also in the tablets and salt.Too much rinse aid can cause the dish washer to froth up and this can overflow down the underside of the door causing the problem you have.
Hope this helped.
May 13, 2010 | Zanussi 23 in. ZDT6255 Built-In Dishwasher
I have a Smeg DWF410 dishwasher with error message E9
E9 is a repetative E1 error - flood protection activated. Check tray under machine for leaks. If dry, find youself a nice long cable tie and lift the rubber flap at the back of the sump moulding underr the filters. Proceed as if rodding out the drains - you'll be surprised how much muck and goo comes out. Usually solves it.
If problem still persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 13, 2009 | Smeg 18 in. DWF410SS Slim-Line...
Dishwasher Reset / Diagnostics
Unscrew and remove the kickplate at the very bottom of the dishwasher. The tech sheet with the diagnostic code should be attached to the back of it.  If not, due a websearch and you should be able to find the info on yahoo or google.
Jan 05, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Nov 20, 2008 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Hi
Jun 22, 2008 | Smeg 18 in. DWD409SS Built-in Dishwasher
Dishwasher stops after rinse
Seems to be an error with the float switch on the anti flood device http://www.smeg-service.co.uk/support/index.php?a=1&cat=4
Apr 18, 2008 | Smeg 24 in. STX2 Built-in Dishwasher
Dishwashers Logo
751 people viewed this question
Top Dishwashers Experts
