Question about GE Monogram ZIC360NRRH Bottom Freezer Refrigerator
GE Monogram damper door
I suspect a problem with the damper door on my GE Monogram bottom mount(ZIC360NRRH). Before I start tearing things apart to find the damper, I'm wondering if anybody can give me some hints on where to start looking (inside, at the back, fridge section, or freeezer section?) Thanks
Why is the refrigerated side freezing food?
Your freezer door seal may be the problem forcing the freezer side to work too long, thus affecting fridge side.
May 31, 2015 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram all freezer about 4 years old has a door seal that won't seal and it ices up at bottom. We have defrosted three times. Is there a way to test if the door is hung crooked?
If the door hang is bent the door wont be vertical you can see it.
You can try taking apart the door and mounting it back.
More likely you need to replace the gasket.
Sep 04, 2008 | Refrigerators
The refrigerator side has sweat running down the side of wall next to the freezer forming water in the bottom. the temperture goes between 41% to 48%. the food spoils. what is wrong?
Without a model number, I could only guess that the automatic damper door that lets cold air in from the freezer section is broken, frozen shut, or just not operational. The refrigerator receives it's cold air from the freezer section. If the freezer is operating correctly, I would asume the damper door is not functioning. Pleazer Appliance...
Jun 06, 2014 | GE Monogram Side by Side Refrigerator
My GE Monogram side by side we can't control the refrig side temp. It just freezes no matter what. We have wasted so much food.
its the damper vent door thats located in the upper left area of the refrigerator compartment and this door breaks and then cant shut to close off the cold air from the freezer entering the refrige,general electric has had a bad problem with these damper vent doors,now they have a new and improved or so they say damper vent door,its about $100.00+
May 29, 2011 | GE Monogram Side by Side Refrigerator
GE part # WR17X11267 This is the ice funnel for a GE Monogram model #ZISS480DRBS refrigerator. HOW DO YOU INSTALL IT? I have been told to "snap off" the trim from around the dispenser. The trim...
The dispenser front will just snap off but the snap tabs need to be pressed (typically 3 in the bottom of the front of the cover). GE has always been bad at their drawings and this might be one of them that requires you to take the door apart. Here is a really good video doing the same thing on a GE (a different model but it works identically).
Feb 19, 2018 | Refrigerators
GE model 25 - 6 years old - Top part of fridge and freezer not cooling. compressor seems to be working fine. Bottom part of freezer is very cold and bottom part of fridge is freezing everything. Appears to...
It sounds like the damper assembly might have failed or be stuck open. The damper is mounted in the left side upper rear corner of the refrigerator section. The damper controls the amount of cold air that comes into the refrigerator section from the freezer.
If you want to repair the refrigerator yourself you should disconnect the power to the refrigerator and remove the 2 screws holding the damper cover to the center wall. Sometimes you can spray the damper with WD40 and free it up.
Jan 30, 2011 | GE Profile PSW26P Stainless Steel Side by...
Water will not dispense when activated by the button on the door
If this is a unit that's been installed a while, check the Quick chill damper on the bottom. Feature Pan ducts air from the freezer via a lower damper....See if it's hung open. This can freeze the water tank which is behind the pan...Another symptom of this, may also see temps acting strangely.
Dec 15, 2010 | GE Monogram Side by Side Refrigerator
Help me with me frige not cooling bottom GE unit.
When you close the freezer door, does the fan turn off? There isn't any thing else on my bottom mount beside the damper that regulates airflow to the refrigerator box.
You should be able to drop a string from the damper opening at the back of the refrigerator down to the duct to the freezer. If you can't there is some obstruction in that duct. I suppose it is possible there is some other mechanism in that duct on your particular model, but I can't understand what its purpose would be.
The picture below shows the vents at the back bottom of the refrigerator box that return air to the evaporator in the freezer box to be re-cooled. If these are blocked, the fan can't draw air in to be blown back up to the refrigerator, unless of course the freezer door is open. 7e3c57e.jpg
Jan 09, 2009 | GE Profile PDS22MHR Bottom Freezer...
GE Monogram ZIC360NRRH Bottom Freezer Refrigerator Logo
258 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
