Question about Olympus C-990 ZOOM Digital Camera
Olympus c90 zoom wont power up
Its completely dead bought it secondhand never used it as i cant get it to switch on
2 Suggested Answers
  • 11967 Answers
SOURCE: Olympus 760 . Zoom wont retract camera/it is fully charged?
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 09, 2010
Power was on, tuned off to insert SD card dropped it, lens zoom out and now wont power on, please help
THAT MAY BE COINCIDENCE. I HAD MINE QUITTING WHILE I WAS GETTING INTO POSITION TO SHOOT A PICTURE. I DIDN'T BOTHER WITH REPAIR AND BOUGHT AN OLYMPUS VR-320. MUCH SIMPLER AND QUICKER TO SHOOT.
Jun 18, 2015 | Polaroid I Cameras
I bought this camera only a couple of months ago. I used it at a maximum three times, but at late it wont charge. I have multiple USB chargers and have used them all, but still wont charge :(
Hi, Check the connections for tightness and use a volt/ohm meter to check for charging voltage. Anywhere between 6v and 12v. If you suspect charger, replace with same kind and Voltage output.
Also check battery(s). replace if dead. After many battery uses. They can have an internal discharge and will not work properly any more.
Good luck.
Jun 06, 2015 | Olympus VG-170 Digital Compact Camera -...
Have tried to load program on new computer but does not complete so now cant use camera
You can always use a card reader to download pics. You don't need the camera software.
Sep 11, 2010 | Olympus D-535 Zoom / C370 Zoom Digital...
Cant get anything when i installed the memory card for my olympus
If this is a C-700 camera the only memory card that can be used in that camera is a Smartmedia card from 16mb to 128mb. An xD card is not even supported by that camera at all.
Apr 02, 2009 | Olympus Camedia C-700 Ultra Zoom Digital...
How to change language setting from Japanese to english
I am going to have to say contact Olympus I have read all their manuals and notes on the camera and cant find nothing for language setting on it.
Aug 07, 2008 | Olympus Camedia C-3020 Zoom Digital Camera
Got software for Olympus D545 camera, but wont install?
I have an Olympus c-480zoom camera.
Have the installation disc which worked fine when first installed. Last week my PC crashed, it's now up and running but will not install the software again. Help !!!
Thanks in anticipation.
Oct 29, 2007 | Olympus D-535 Zoom / C370 Zoom Digital...
Memory card problems
C-Series : Optical zoom lens cameras with sliding lens cover Product name xD-Picture Card *1-7 SmartMedia
3V(3.3V) CompactFlash Type M+ / M Type H Standard C-990ZS - - - X
2MB - 128MB - C-990 ZOOM - - - X
2MB - 128MB - C-960 ZOOM - - - X
2MB - 128MB - C-920 ZOOM - - - X
2MB - 128MB - C-900 ZOOM - - - X
2MB - 32MB - C-500 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-480 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-470 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-460 ZOOM X
256MB - 1GB X
256MB - 2GB X
16MB - 512MB - - C-450 ZOOM X
256MB - 512MB X
256MB - 512MB X
16MB - 512MB - -
http://www.olympusimage.com.sg/pr/notice/1176786_707.html
check up at this website
Sep 22, 2007 | Olympus Camedia C-450 Zoom Digital Camera
Olympus Camedia C5050 Zoom
The unusual beeps usually occur when the lens cannot be extended or retracted, often due to dirt in the gearing or the lens cap being left on.
Try using canned air to blow around the outside of the extension cylinder, and, putting a fresh set of batteries in the camera (it probably got stuck on since it couldn't fully retract the lens and didn't complete the shutdown).
If that doesn't work, try taking it to a camera store with repair technicians and having them take apart and clean the lens extension/retraction mechanism.
Aug 19, 2007 | Olympus Camedia C-350 Digital Camera
Dead c 310
that camera needs to have the mainboard replaced, it´s pretty normal, with that kind of model
Nov 28, 2006 | Olympus Camedia C-310 Zoom Digital Camera
Olympus C-990 ZOOM Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
