Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
F7 error code
kmitchell205 on May 08, 2007
I have the dreaded F7 code on my GE Profile single oven. I see listed under your name you have the magic solution! Can you share some help?
Thank you so much! Kathryn
Comments:
May 09, 2007
- Worked like a charm. Your instructions worked perfectly and it took no time at all!!!!
Thanks a million!!!!!!
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Feb 12, 2009
-   I have a GE oven model number JGRS14BEW3BB with a F7 error message and a beeping noise. Do you have a solution for my problem? Email: marleigha@yahoo.com-   marleigh
Feb 06, 2009
-   I have a GE JRP15BOW4BB built in oven with the dreaded "F7" problem - oven not working, beeping. This is an intermitten problem. What can I do?
limomants@aol.com-   limomants
Jan 10, 2009
-   what does an F7 mean and how to fix-   Guest
Jan 05, 2009
-   if (typeof YAHOO == "undefined") { var YAHOO = {}; } YAHOO.Shortcuts = YAHOO.Shortcuts || {}; YAHOO.Shortcuts.hasSensitiveText = true; YAHOO.Shortcuts.sensitivityType = ["adult"]; YAHOO.Shortcuts.doUlt = false; YAHOO.Shortcuts.location = "us"; YAHOO.Shortcuts.document_id = 0; YAHOO.Shortcuts.document_type = ""; YAHOO.Shortcuts.document_title = "kenmore oven F7 problem....heard you might be able to help... :)"; YAHOO.Shortcuts.document_publish_date = ""; YAHOO.Shortcuts.document_author = "jancarrollreynolds@yahoo.com"; YAHOO.Shortcuts.document_url = ""; YAHOO.Shortcuts.document_tags = ""; YAHOO.Shortcuts.document_language = "english"; YAHOO.Shortcuts.annotationSet = { "lw_1231191640_0": { "text": "kenmore", "extended": 0, "startchar": 142, "endchar": 148, "start": 142, "end": 148, "extendedFrom": "", "predictedCategory": "PLACE", "predictionProbability": "0.594531", "weight": 0.33121, "relScore": 4.71104, "type": ["shortcuts:/us/instance/place/ambiguous"], "category": ["PLACE"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "able to help us. We have a 6 yr old kenmore single oven that has had times over the last 3", "metaData": [ { "geoArea": "0.896589", "geoCountry": "United States", "geoCounty": "Suffolk", "geoIsoCountryCode": "US", "geoLocation": "(-71.089287, 42.345009)", "geoName": "Kenmore", "geoPlaceType": "Suburb", "geoState": "Massachusetts", "geoStateCode": "MA", "geoTown": "Kenmore", "geoZip": "02215", "type": "shortcuts:/us/instance/place/us/suburb", "visible": "true"}, { "geoArea": "16.6874", "geoCountry": "United States", "geoCounty": "King", "geoIsoCountryCode": "US", "geoLocation": "(-122.24366, 47.758389)", "geoName": "Kenmore", "geoPlaceType": "Town", "geoState": "Washington", "geoStateCode": "WA", "geoTown": "Kenmore", "geoZip": "98028", "type": "shortcuts:/us/instance/place/us/town", "visible": "true"} ] }, "lw_1231191640_1": { "text": "770-864-0003", "extended": 0, "startchar": 562, "endchar": 573, "start": 562, "end": 573, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 1, "relScore": 0, "type": ["shortcuts:/us/instance/identifier/phone_number/us"], "category": ["IDENTIFIER"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "would really be appreciated. Thank you, Paul and Jan Reynolds 770-864-0003 678-643-7378 Ahhh...imagining that irresistible \u0022new car\u0022 smell? Check out new", "metaData": { "visible": "true" } }, "lw_1231191640_2": { "text": "678-643-7378", "extended": 0, "startchar": 578, "endchar": 589, "start": 578, "end": 589, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 1, "relScore": 0, "type": ["shortcuts:/us/instance/identifier/phone_number/us"], "category": ["IDENTIFIER"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "really be appreciated. Thank you, Paul and Jan Reynolds 770-864-0003 678-643-7378 Ahhh...imagining that irresistible \u0022new car\u0022 smell? Check out new cars", "metaData": { "visible": "true" } }, "lw_1231191640_3": { "text": "new cars at Yahoo! Autos.", "extended": 0, "startchar": 887, "endchar": 911, "start": 887, "end": 911, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 1, "relScore": 0, "type": ["shortcuts:/us/instance/identifier/hyperlink/http"], "category": ["IDENTIFIER"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "", "metaData": { "linkHref": "http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-", "linkProtocol": "http", "linkRel": "nofollow", "linkTarget": "_blank", "visible": "true" } } }; YAHOO.Shortcuts.headerID = "031979dd1c36ee45783219b0422bd128"; Hi,
I had come across you from a blog and we were hoping you might be able to help us.
We have a 6 yr old kenmore single oven that has had times over the last 3 years of beeping the F7. We usually shut off the breaker for awhile and when we turn it on, it works for awhile, and then we have to turn it off again to temporarily fix the problem.
As of late, it is getting worse and the F7 is more and more frequent. Any advice would really be appreciated.
Thank you,
770-864-0003
-   janreynolds
Dec 27, 2008
-   f7 is just flashing i cant use the oven-   marinka0505
Best Solution
posted on Sep 04, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Easy fix: Just carefully disconnect the ribbon from the slot, get a pensil eraser and use it on both side of the contacts, slide it back in and you are set.
Solution #2
posted on May 09, 2007
Very Helpful)
Powerman
Rank: Guru  GE ExpertGE Expert
Rating: 91%, 246 votes
Hi Kathryn, I believe that I have already sent you my solution via another route. Hope you received it. Basicaly for anyone else with this problem, it is caused by a short circuit envolving the ribbon cable which connects the touchpanel to the electronic control. The solution varies slightly depending on whether you have a metal or plastic touch panel.
If you have a plastic touch panel,you need to add some extra insulation between the two pieces of ribbon cable in the slot where it exits the touchpanel. You need to slip it down as far into the slot as it will go. A piece of paper, a piece of file card, a thin piece of mylar will all work just fine.
If you have a metal touchpanel, you need to insulate the edges of the slot as well with paper or mylar. Insulate both edges.
If you don't have two sections to the ribbon cable, obviously you can't put insulation between the sections.
If you have a plastic touch panel and only one section to the ribbon, you are out of luck. There is nothing you can do except to purchase a new touch panel.
Cleaning the contacts is a myth. It doesn't help. Hope this helps. Please let me know your results.
Contact me at hutchipop@yahoo.com. Regards, Charlie
Comments:
May 09, 2007
- Here is a photo of my fix when you have a plastic touchpanel. If you have a metal touchpanel, you also need to add insulation between both sides of the ribbon cable and the edges of the slot in the touchpanel.
May 09, 2007
- Here is a photo of my fix when you have a metal touchpane. This shows extra insulation added between the ribbon cable and the edges of the slot as well as between the two sections of ribbon cable.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Sep 10, 2008
Somewhat Helpful)
cutoman
Rank: Apprentice
Rating: 76%, 2 votes
I owned a single wall mounted GE oven and kept getting F7 error. I am not sure the model number, With the F7 error displayed, I cannot use the owen at all.
Any tips on how to fix it would be greatly appreciated.
Thanks.
Comments:
Sep 29, 2008
- F7 error displayed on the control panel just stopped my oven from functioning completely
Was this helpful?
Yes
No
Solution #4
posted on Nov 28, 2008
Very Helpful)
jake7338
Rank: Apprentice
Rating: 100%, 1 votes
I inserted the paper and cleaned the connectors with an eraser. However, i felt that ultimately the ribbon cable was not properly seated in the connection to the big circuit board. When i re-assembled it the ribbon cable went much deeper into the socket then i originally found it. My oven is fixed and working properly now. Thanks for everyone's help.
The hardest part is reattaching the face bezzle. I can't get the two pegs on the top corners to catch and make it flush. Any tips on this?
thanks,
jake
Atlanta, GA
Comments:
Dec 18, 2008
- Nevermind, my oven isn't fixed. The F7 error came back. I may have to get a new keypad for it.
jake
Atlanta, GA
Was this helpful?
Yes
No
Solution #5
posted on Nov 23, 2008
Very Helpful)
chris168
Rank: Apprentice
I have GE Profile Wall Oven. I had F7 error too.
First time it shows, turning off power to owen worked fine.
It showed up a couple times and now turning off power didn't work.
And the touch panel stop functioning altogether.
I was scepticle about the solutions offered here.
But I gave it a try anyway. What do I have to lose, I can't even turn the oven light on.
1 - Added paper insulations on ribbon cable.
2 - Cleaned ribbon cable connector using a pink erasor. :)
IT WORKED like a charm. F7 error went away. Touch pad working like before!
BTW, I didnt' even disconnect copper wires to detach from the oven.
Worked on it while it was hanging. (turn off the power to the oven first, ok?)
Saved some time and avoid the risk of wrong reconnect.
THANKS to Charlie solution and Powerman pics.
Was this helpful?
Yes
No
Solution #6
posted on Sep 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Big help. Problem solved. GE should be making owners aware of this problem ASAP.
Related Problems
Bake push button pressed and temp set ok. When I press Start...
It started with a beep and the word set on the left of the...
Getting F3 and F2 codes on the readout. Sometimes works,...
Can you Help with these Oven problems?
GE JCKP16GS-1 electrical question
Solve
I have this model oven from the USA but am living in Europe. Anyone know how I can connect this for... (More)
oven fan keeps running
Solve
Oven seems to be shut off but convection fan keeps running.
start button not working
Solve
I can enter bake and temp but when i press start nothing happens so the oven never turns on...help... (More)
F7 Question
Solve
My GE Profile is also reading the dreaded F7 code and turning off the electricity does not help. I... (More)
21 Other Users Have The Same Problem - Continued
Comment by ridgefarm, posted on Dec 02, 2008
Same problem. Oven operates intermittenly, F7 error code flashes, and oven beeps randomly. Help!
Comment by Guest, posted on Nov 20, 2008
same issue
Comment by Guest, posted on Nov 18, 2008
getting error 7 code. oven shuts off
Comment by MOTOXRACER, posted on Nov 17, 2008
I FIXED THE F7 PROBLEM BUT NOW THE START BUTTON DOES NOT WORK. I STILL CANT BAKE HELP ME.
Comment by donnayates, posted on Nov 06, 2008
F7 error code and all buttons lock up; the only way to stop it is to turn braker off.
Comment by Guest, posted on Nov 01, 2008
Oven was working perfectly, then I cleaned around the control panel. Oven showed an F7 error code and hasn't worked since.
Comment by markw421, posted on Oct 30, 2008
I am in the process of replacing both the keypad and control module, but am experiencing difficulty in removing the old ones. Do I need to pull the entire unit out in order to do this?
Comment by Guest, posted on Oct 17, 2008
Twice now, in the middle of the night, F7 starts beeping. Buttons are locked up.
Comment by Guest, posted on Aug 29, 2008
f7 message keeps coming on ge wall oven
Comment by tamollie4, posted on Aug 02, 2008
Have a GE Profile wall double oven with the F7 error code. Would like to try to repair it before spending big bucks when a simple home repair will do
Thanks
Comment by jamesonblue, posted on Jul 27, 2008
Have a GE double oven...F7 error code on both of them...tried cleaning the ribbon ends...error came back after about 1 week...have had this problem for about 1 year...about ready to buy a new oven...ouch!
Comment by tmbell, posted on Jul 11, 2008
F7 code keeps beeping what do i do?
Comment by Chriswelch, posted on May 20, 2008
Touch pad does not work F7 error code, I shut circt breaker off for 1 hour and touch pad still does not work!
Please help ? I need instuctions on how to get repaied.
Comment by Guest, posted on May 19, 2008
my GE oven is beeping constantly and shows the F7 code. Nothing I do will make it stop. Help, please.
Comment by hasans, posted on Feb 23, 2008
ist f7 code, i cleaned touch pad then start and clear button does not work but f7 code did not come back
Sponsored Links
Describe your Appliance problem:
Top Oven Experts
Rank: Guru Guru
Solutions: 9503
Experience: Do it-your-selfer for a lifetime, 35 years of electrical and mechanical professional exp.
Ask Me
Find more Oven Experts
Top Ranges & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
