Question about Ovens
RELAY STUCK READING ON WOLF DOUBLE OVEN DO30F
HAD OVEN SET AT 425 - BEEPER WENT OFF - READ OUT SAYS
RELAY STUCK - NOTHING IN THE WOLF PROVIDED MATERIALS TO INTERPRET READOUTS
5 Suggested Answers
SOURCE: I have a wolf double oven D030F/S. cannot get
My lower oven will not heat up (Model D030FS) in broiler, bake or clean mode.
Posted on Jun 25, 2011
fridgetech
  • 473 Answers
SOURCE: Temp. problems on a GE wall oven
Give me the complete model # from the tag on the oven and I will look into this for you.
Posted on Nov 07, 2007
espressonist
  • 1711 Answers
SOURCE: My whirlpool double oven accubake GBD307PDS09
We have here a video showing how you can check the temperature sensor
We also here the parts diagram of your model
Posted on Aug 20, 2011
burkcs
SOURCE: Whirlpool Double oven control panel
A lot of people seem to have ran into this problem. I had no luck finding a solution to this problem anywhere on the internet. I finally fixed this problem by replacing the control board. Wanted to put this info out here for others. The part swaps out fairly easy for all of you considering the fix yourself. Sears direct had the cheapest price.
Posted on Dec 24, 2012
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
I have a wolf range and the oven temp when set at 350 degrees, flucuates between 333 and 376 degrees. This avg. out to 354 deg, but stuff does not bake properly and I have to add time. Is this normal for...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 29, 2011 | Wolf Range Ovens
Oven does not get to temp when it says its preheated
More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
Feb 10, 2010 | GE Ovens
How to clean gas wolf oven
No. Because if you dont get all the cleaner off you dont know if it would be toxic or not.
Jan 16, 2009 | Wolf Range WKGD-2 Gas Double Oven
Oven Doesn't Reach Set Temperature
Check the element for burns/wholes this was problem for our.  Easy fix and part is about 35 to 40 dollars.
Nov 16, 2006 | Thermador SC272T Electric Double Oven
Ovens Logo
716 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
