Question about Compaq Armada M700 Notebook
System board comm fault
When powering up, the computer gives 2 beeps and the following error message is displayed "1155-System board comm port address assignment conflict". You then get two options; F1- Boot F10- Computer setup Selecting F1 boots the computer, loads operating system with no apparent problems. Is this error a concern and if so, how do I fix it.
  • Anonymous Sep 30, 2008
    1155 system board comm port address assignment conflict
Conda, what are the steps one generally takes to resolve an IRC conflict? Where is the UI? Is setting in the OS or BIOS or both?
Posted on Aug 15, 2008
    Problem Solver:
  • 8 Answers
All parts for your specifuc model can be found at: http://h20141.www2.hp.com/hpparts/ then on left side of page, click on the "search for a part" link In the "Search by model number, enter you notebooks model # of 139116-002. This will then givr you 3 options, 2 menues, and onr for ALL parts available for your system. Click on that "List all parts for this product" (ot the little 2 arrows at the end of that sentence).
Posted on Jun 13, 2007
  • Darrin McGee Jun 13, 2007
    After searching throughhttp://partsurfer.hp.com (where you can look up all parts, not just the 1st 100), it DOES show that you need to get the WHOLE LCD Assembly. Is your notebook under warranty by chance?? Have you registered it with HP/Compaq? If not, I can help you there, being an HP, Compaq, Toshiba, IBM and Dell Certified Technician....and could help you register it and get your parts under warranty, perhaps..
    So just email me at: bosscomputers@comcast.net and we can go from there! Always glad to help!
    Problem Solver:
  • 12 Answers
Sounds like an IRC Conflict with one of your devices. Go into your control panel , computer managment, device manager and see if any devices have an ! beside them and try to re-install the drivers for the affected piece of hardware. Make sure they have all the correct drivers installed. Have you installed any new hardware? what OS are you running? If you have installed new hardware into your machine, it could be a jumper issue. Have you checked your settings in the BIOS or modified any settings in there? You could also try to reset your BIOS back to factory default settings if you have been changing settings, that could also lead to your problems.More info is needed to help you further. Good Luck
Posted on May 08, 2007
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
Tip
Tipical Computer/Laptop Post & Beep Error Codes
Error Code: Faulty Component:
_____________________________________________________________
1 short beep None (Normal Boot)
2 short beeps ( POST error)
Non-stop beep ( Power supply or system board)
1 long beep and 1 short beep ( System board)
1 long beep and 2 short beeps ( Video card)
1 long beep and 3 short beeps ( Memory)
3 long beeps ( Keyboard)
Non-stop short beeps ( Power supply or system board,a key on the
keyboard might also be stuck)
None ( Power supply,system board,or system
case built-in speaker)
______________________________________________________________
Visual POST Error Codes:
Error # Range: Component with Error:
100-199 System Board
200-299 System Memory (RAM)
300-399 Keyboard
600-699 Floppy Drive or Floppy Controller
700-799 Math Co-processor
900-999 Parallel Port (LPT1)
1000-1099 Parallel Port (LPT2)
1100-1199 Serial Port (COM1)
1200-1299 Serial Port (COM2)
on Oct 01, 2010 | Computers & Internet
Tip
Error Codes you need to know.
Standard Original IBM POST Error CodesCode Description
1 short beep System is OK 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Display adapter problem (EGA) 3 long beeps 3270 keyboard cardIBM POST Diagnostic Code DescriptionsCode Description 100 - 199 System Board 200 - 299 Memory 300 - 399 Keyboard 400 - 499 Monochrome Display 500 - 599 Colour/Graphics Display 600 - 699 Floppy-disk drive and/or Adapter 700 - 799 Math Coprocessor 900 - 999 Parallel Printer Port 1000 - 1099 Alternate Printer Adapter 1100 - 1299 Asynchronous Communication Device, Adapter, or Port 1300 - 1399 Game Port 1400 - 1499 Colour/Graphics Printer 1500 - 1599 Synchronous Communication Device, Adapter, or Port 1700 - 1799 Hard Drive and/or Adapter 1800 - 1899 Expansion Unit (XT) 2000 - 2199 Bisynchronous Communication Adapter 2400 - 2599 EGA system-board Video (MCA) 3000 - 3199 LAN Adapter 4800 - 4999 Internal Modem 7000 - 7099 Phoenix BIOS Chips 7300 - 7399 3.5" Disk Drive 8900 - 8999 MIDI Adapter 11200 - 11299 SCSI Adapter 21000 - 21099 SCSI Fixed Disk and Controller 21500 - 21599 SCSI CD-ROM System
on Mar 09, 2010 | Computers & Internet
Dell Optiplex 725 Beeps at me at me at start up w/o complete start up. Screen Black. As if something is loose? Battery in Motherboard? Did something short out?
POST Beep Codes: OptiPlex GXi If the monitor cannot display error messages during the POST, the system may emit a series of beeps that identifies the problem or that can help you identify a faulty component or assembly. The following table lists the beep codes that may be generated during the POST. Most beep codes indicate a fatal error that prevents the system from completing the boot routine until the indicated condition is corrected.
Beep Code Error Probable Causes 1-3 Monitor not detected Disconnected or faulty monitor 1-1-3 NVRAM write/read failure Defective system board 1-1-4 BIOS checksum failure Faulty BIOS or defective system board 1-2-1 Programmable interval-timer failure Defective system board 1-2-2 DMA initialization failure Defective system board 1-2-3 DMA page register write/read failure Defective system board 1-3-1 Main-memory refresh verification failure Faulty or improperly seated DIMM or defective system board 1-3-2 No memory installed No memory installed or faulty or improperly seated DIMM 1-3-3 Chip or data line failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-3-4 Odd/even logic failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-4-1 Address line failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-4-2 Parity failure in the first 64 KB of main memory Faulty or improperly seated DIMM 2-1-1 through 2-4-4 Bit failure in the first 64 KB of main memory Faulty or improperly seated DIMM 3-1-1 Slave DMA-register failure Defective system board 3-1-2 Master DMA-register failure Defective system board 3-1-3 Master interrupt-mask register failure Defective system board 3-1-4 Slave interrupt-mask register failure Defective system board 3-2-4 Keyboard-controller test failure Faulty keyboard controller (defective system board) 3-3-4 Screen initialization failure Faulty video subsystem (defective system board) 3-4-1 Screen-retrace test failure Faulty video subsystem (defective system board) 3-4-2 Search for video ROM failed Faulty video subsystem (defective system board) 4-2-1 No timer tick Defective system board 4-2-2 Shutdown failure Defective system board 4-2-3 Gate A20 failure Defective system board 4-2-4 Unexpected interrupt in protected mode Defective system board 4-3-1 Memory failure above address 0FFFFh Faulty or improperly seated DIMM 4-3-3 Timer-chip counter 2 failure Defective system board 4-3-4 Time-of-day clock stopped Bad battery or defective system board 4-4-1 Serial-port test failure Faulty I/O chip (defective system board) 4-4-2 Parallel-port test failure Faulty I/O chip (defective system board) 4-4-3 Math coprocessor failure Faulty microprocessor chip or system board 4-4-4 Cache test failure Defective microprocessor or system board
Mar 30, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Can not reinstall os on mt acer 246lc it bleeps 4 times and swithes off
Without knowing what motherboard is in the unit - it will be difficult to determine what the 4 beeps means.
Generally, 4 beeps means issues with :
- memory
- video card
- keyboard
- motherboard failure
Things to try -
- make sure there is no keys stuck down
- remove the battery and AC adapter, remove and re-install the memory sticks (reseating the memory)
If this does not work, your problem may be more serious. Let us know the results of the above suggestions.
Nov 17, 2009 | Acer Computers & Internet
Tip
Beep Codes (Different BIOS) " What they mean "
Code Description
Code Description
200 - 299 Memory
300 - 399 Keyboard
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
on Dec 30, 2009 | Computers & Internet
Erro sound/pip when ibm 8310 netvista starts, no error message are show on the screen, the screen are black.
how many times it beeps is an indication of the problem
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard cardhope this helps.
Sep 14, 2009 | IBM (09N5424) Motherboard
Beep sound continus
I went to google and it seems like the beeps can be problems for different problems in the hardware, this is what one message says,  there are lots of computer beeping answers out there: 1 short beep is your BIOS saying "HELLO I'M OK"
1 short beep Normal POST - system is ok
3 long beeps keyboard card
Each BIOS company has modified these codes over the years.
May 25, 2009 | Dell Dimension 4600 PC Desktop
4 beeps 2373 laptop
Code Description
Code Description
200 - 299 Memory
300 - 399 Keyboard
AMI BIOS Beep Codes
Code Description
Code Description
2-_-_ Faulty Memory
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
Beeps
Code Description
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
Compaq Armada M700 Notebook Logo
518 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
