Question about Xerox DocuColor 12 Color Copier
White lines Xerox docucolor 12
Hi, When I changed the developer, got rid of the 9-363 error, however I will check the fuses too. Thanks for the advice.
If I get white lines through the whole length of the paper, what do you think it can be. I changed my photoreceptor (print cartridge), fuser roller, 2nd BTR, and checked my 1st BTR for any marks/damage, but everything looks O.K. Still get the white lines. Do you think it can be the paper type? This occurs especially when printing all solid colors. Don't really see it on photos/
Does PWB stand for Printed Wire Board?
Thank you!
  • 1 more comment
  • howsimple Jan 02, 2009
    Yes, it is one color, white. It is a single white thick line along the whole length. If it is short and thin, would that be the wire in the print cartridge that needs cleaning? Thank you!
    Yes, it is lead edge to trail edge. I have another back up machine and will be able to replace the whole part. Thank you!
  • howsimple Jan 08, 2009
    I was able to correct the problem with your expert advice on Fixya. You definitely make fixya.com a very valuable service. Thanks for answering my questions
  • 62 Answers
Do an emergency stop on the machine as the paper is just coming into the main path, and you will catch the inage on the IBT. with a bit of luck on the drum as well. Is it not in 1 colour the white lines? Also are they thick or pencil like lines and from lead edge to trail edge?
Posted on Jan 01, 2009
  • oooimstuck Jan 02, 2009
    Is the white line in any one particular colour. Do you think you might just need to get someone who knows about these machines to service it properly? Thin pencil lines from lead edge to trail edge are usually the developer housing contaminated. I'm gonna guess at that seeing as you have been in that area. You never told me if it was lead edge to trail edge or not.
    Do you know how to get into diagnostics on the machine UI? If so use the print button and selext number 11 and a colour, it will giv you an indication if there is a problem in any particular problem
Error code 10-356
Hi
10-356 code i pws mode
remplace the fuser
Feb 09, 2010 | Xerox DocuColor 12 Printer
DOTS pattern and WHITE LINE along the page
The Problem is your Copy Print Module it has a scracht on it if you replace the module it will desapear the dots and lines.
Nov 26, 2009 | Xerox DocuColor 12 Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Docucolor making lines
Hi!
Have you tryed to switch drums (magenta - yellow)? There may also be a problem with developer. If it is not your Magenta drum, it might be the fuser as well - if you pull out your fuser and look on that outside area, you may see a bunch of squiggly lines on it. If so, replace it. If neither your drum replacement or fuser replacement does it, then it is the developer which needs replacement.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Xerox DocuColor 12 Printer
Docucolor 12 no print
if its a print from system to machine do the following
1: check the cables from fiery to machine
2: press clear server in the fiery menu
its not ok
next time mention fiery model
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
Error 9-363 Xerox
well I dont know how extensive you want to get but is what is happened is the Black developer housing has gotten to much toner in it and it is packed in there. The solution to the issue is to replace the developer material. with new. It may not be nessasary to replace the housing but that may also need to be replaced.
Dec 31, 2008 | Xerox DocuColor 12 Color Copier
Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
Your Problem is the cartridge printer Mx, In spanish algun balero de las developers units esta dañado pudiera estar golpeando el cilindro de imagen
Nov 03, 2008 | Xerox DocuColor 12 Printer
Xerox Docucolor 12 color copier language problem
Hi, there is no way to change language on Touch screen without calling Service. Best regards.
Dec 27, 2007 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Color Copier Logo
226 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
