Question about Photography
Vivitar tripod V900 has a broken friction level
The V900 tripod has extending legs that are held by small red friction levers. One of these levers has broken, leaving me unable to extend and tighten that leg. This has been a great tripod and I hate to have to toss it for lack of such a simple part. Thanks.
  • toddsifert2 Feb 14, 2009
    I have not yet found a fix for this tripod. I did just purchase a digital camera, so I will try to post a picture. I searched for used tripods that I could scavenge for parts, but did not find one on ebay, craigslist, or amazon.
    Smileclick - are you not using your tripod because it is broken, or have you just replaced it?
  • cwhiz4u May 11, 2010
    can you post a pic of the lever?
Ok, never used this site before and not sure I know what I am doing. Did you get your tripod fixed? I have the exact same tripod but am no longer using it.
Posted on Feb 14, 2009
  • smileclick Feb 15, 2009
    I have replaced it just a few weeks ago with a new heavy duty one as I am getting into the photography thing!! (and might I add loving it!) I was trying to find a price on this one to put it on my company bulletin board and try to sell it. I have no use for it and it is in good shape and all red levers work. If you are interested in it let me know how I can go about getting it to you.
  • smileclick Feb 22, 2009
    toddsifert2 - haven't heard back from you. Did you get your tripod fixed?
  • 24 Answers
Vivitar has been out of the tripod business for a few years now. They may no longer have the parts. You may be able to find another V900 and scavage the parts. Make sure the model numbers match exactly. The V900SE is a different year and does not share the same parts as the V900.
Posted on Feb 10, 2009
Vivitar 980 leg lock replacement
Who are these people designing the leg locks. These are the poorest examples of engineering. Even a child could see that the leg lock begs to be broken. Maybe Vivitar should stick to flashes
Apr 22, 2012 | Vivitar Photography
One of my Tripod legs is bent and I can't pull it out.
You can attempt to bend it back using a table and attempting to lever it.
If this doesn't work you will need to replace the tripod. You can get a decent tripod for around $40.
Mar 04, 2011 | Vivitar V-2400GX Tripod
I have a Vivitar 50x/100x telescope. One of the
No replacement parts available for that telescope. Suggest you take the tripod to a well stocked hard ware store and see if they have any screws, bolts, or clamps that would repair the tripod.
You can buy another photo tripod of course.
Oct 23, 2009 | Vivitar Optics
Leg slips will not lock
Although I'm not familiar with your particular make and model it sounds like a common problem which affects many other tripods. If the legs clamp with a lever action then if you closely examine each clamp as you activate the lever I expect that you'll find a small crack opens up in the clamp assembly.
It's a faulty design as the clamps simply aren't strong enough for the load and eventually crack due to fatigue. Some manufacturers supply replacement leg clamps but they also fail and fitting them usually costs more than the tripod is worth.
Next time, consider buying a tripod which has rotating collars to lock the legs with. They're not as quick to operate as lever action (a.k.a. "quick release") clamps, but they don't take much longer and last far longer. Rotating collar clamps are only suitable for tubular legs, and to be as rigid as extruded profile legs there's usually an increased weight penalty unless you spend far more on carbon fibre versions.
Personally, I tend to buy cheap but perfectly good non brand name lightweight tripods which I can get for £10 including a carry bag and handle and expect to have to replace them when broken: usually about once a year. It's a lot cheaper than spending over £300 on a good one and means I can afford to have a spare one in the car.
ALDI (in the UK and Europe) sell a £10 tripod which comes with a handle, carry bag, pan/tilt head,quick release leg clamps, geared centre column plus two quick release mounting plates and has a bag hook at the bottom of the centre column; it even has a no quibble three year guarantee. It's not a smooth or as well built as many, but can't be beaten at the price.
Aug 06, 2009 | Vinten 3770-3 Tripod
Plastic locks Vivitar V900 tripod are breaking.
the plastic locks on our vivitor 980 tripod legs are broken now can i replace them. jan
Mar 17, 2009 | Photography
Focal tripod
I have a Focal tripod model # 20-08-87 that is missing the quick release plate. I cannot seem to locate a replacement. Can you help me locate one??? Thanks, Jackie
Mar 01, 2008 | Sanford Traveler Tripod
Can't figure out how to straighten and level the camera
if you have lost a srew or wing nut, it will be loose where there should be one. set it up and then try to raise or move it around in one spot. iof it moves than look for a screw hole. the handle itself sets the rotation try unloosing the handle..
Dec 31, 2007 | Quantaray QSX-DigiPro 8500 Tripod
Vivitar V3000 Tripod
I did not have any luck in locating the leg locking assembly for my Vivitar V3000. Instead, I plastic welded both that were broken on mine. So far, so good!
Dec 14, 2007 | Vivitar V-2200GX Tripod
One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
May 26, 2007 | Velbon Ultra MAXi Tripod
Photography Logo
476 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
