Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn Air Refrigerator
Hello Catriver:
I have another issue that I could some help on. By the way, I appreciate your help on the other items in the past.
I have a Jenn-Air side by side refrigerator that does not cool well on the refrigerator side. I have at least tracked down the issue to the evaporator coils on the freezer side. They are not defrosting. I'm dragging out the hair dryer about once a week, and it's time for a real fix.
I've read other comments about similiar issues with the same model. I've tested the continuity on the heater coil and it appears that it does NOT close the loop. I can not get a "zero" reading when plugging the ohm meter into the snap plug for the heater. It reads something like .02 and never zero regardless which wires I attach to. Now if that doesn't confuse me enough, there is a routine clicking noise coming from the refrigerator cabinet at or very near the adaptive defrost control. I'm real confused and could use some direction before I start buying parts.
Thanks in advance for any direction.
Tom
  • 3 more comments
  • Tom Lawrence Jan 02, 2009
    Thanks Catriver, I'll give that a try on Friday and report back.
    Hey Catriver,
    Is there a trick to removing the control panel cover? It seems to be binding on the styrofoam vent coming from the freezer compartment. Do I need to remove anything from the other isde to get this thing off? I hate to force it, I know it will break easy. Thanks in advance for your help.
    Tom
  • Tom Lawrence Jan 03, 2009
    Thanks Catriver, I'll report back soon.
  • Tom Lawrence Jan 21, 2009
    Catriver, I replaced the Adaptive Defrost Timer and I think it's working. I'll know in a couple of days. Thanks for your help!!
  • Tom Lawrence Feb 06, 2009
    To all reading this post. Jenn-Air was willing to pay for the Adaptive Defrost Timer, however you were required to hire an authorized repair agent. I opted to repair it myself. If you can not make that repair, call Jenn Air and at least have them pay for the part.
    President:
  • 878 Answers
Hi Tom, I think the clicking you are hearing is the board jumping into and out of defrost. You can test it your self by shorting L1 to test on the board. If it goes into defrost and jumps right back out (another click) it's probably the board. Unplug the harness and measure the continuity between 2 and 3 on the disconnect plug. On the Rx 1 scale you should read 20 to 40 ohms. If you have that the heater and T stat are ok. If not then go after the heater and T stat. The heater should ohm out at about 26.5 ohms. When you do the resistance checks on 2 and 3 make sure to unplug it from the board and have the power off. I believe it is a yellow and white/blk wire. Catriver
Posted on Jan 01, 2009
  • Ron Marek
    Ron Marek Jan 03, 2009
    Tom, in back there are two square holes that you can put a finger in on each side. Pull down at the rear in these holes and pull the panel straight out as you are pulling down. These can be a real beast. I have broken many in my time. You might try one side at a time until they release. Catriver.
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
About how old is the jenn-air model# jcd2389des?
Hello, Thank You for using FixYa. I will be helping you today.About seven years old.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Jenn-Air JCD2389G Side by Side...
I have a Jenn-Air side by side refrigerator. JRSD209T. Water fills up the ice shute and runs into the floor. What stays in the freezer freezes in the chute. What do I need to change to fix this problem
From your description I'll gather you're not getting ice cubes either and need to replace the ice maker
Part # D7824706Q on the diagram labeled "Lights and Ice maker" it's item 1
This is from Sears so you can order and have it delivered to the house
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2295HES/1266/0165000?pathTaken=
Jan 01, 2011 | Jenn-Air JCD2295HES Side by Side...
What water filter does it use?
hello there
Item #
1446373 Price
$41.65 In Stock?
Yes Maytag/Amana/Jenn-Air PuriClean II Refrigerator Water Filter - The PuriClean II water filter is manufacturer part number UKF8001AXX. It is a high-quality carbon filter that reduces contaminants such as lead, cysts, pesticides, herbicides and much more. Replace annually or when the filter light is on.e643401.jpg
Jul 27, 2010 | Maytag MSD2656G Side by Side Refrigerator
Frigerator not working
2 possible issues. freezer fan is not working ,should be able to hear it inside frz.2nd issue auto defrost is not working, look for ice/frost build up on rear wall of frz.possible timer or heater issue Hope this helps ,pleases rate my response :)
Jun 25, 2009 | Jenn-Air Jenn Air Side-By-Side...
Jenn-Air not Cooling...
Sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
Feb 15, 2009 | Jenn-Air JCD2295K Stainless Steel Side by...
Jenn air refrigerator temp gauge problem
Hi again,
In your particular model I believe it is termed as "MaxCool". It is also possible that the sensor for the refrigerator is covered by a food item and therefore was getting erroneous readings hence cutting off early (making the temp go higher than normal). Based on this, you can try switching the food items around relocating them as to how they were placed inside. Incidentally, frequent opening and closing of the refrigerator of course would be exposing the inside to warmer air making the unit work harder.
The reset requires that the unit be unplug for an hour or more hence my suggestion during the Live Session to make use of a second refrigerator while checking out the Jenn Air.
Jun 02, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
JENN-AIR BLOWS WARM AIR
Towards the bottom of the freezer is the water diversion tray for when it defrosts. It is usually made of glass but may not be. Lift that up an see if it is blocked by frozen water ice blocking the cold air vent that recirculates and also feeds into your refrigerator.
If this doesn't help wait long enough and one of the other experts on the site will help you. If it does solve your problem I wouldn't be too surprised as I've seen this so many times.
Well, regards and good luck,
Worldvet
Jun 02, 2008 | Jenn-Air JCB2280HES Side by Side...
Icemaker problems
Woody, This is one of the easier dispenser assy. to fix. The flapper is pretty simple, it clips on to the hinge assy. The hinge assy. has a spring that closes the flapper. There is a selenoid that pulls the flapper open. You can look up the parts on the net to see what they would cost. Flapper-12562701, hinge assy. 67004119, solenoid-12575401,spring 12565502. I don't know if you need all of them, Im not there to see. But if you have some time on your hands you could save a lot of money doing it yourself. Once fixed, you should be good for a long time. Catriver.
Jul 24, 2007 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
235 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
