I have a frigidaire gallery top load washer that is 5 years old. Tech said that the bearing was going. Screams like a pig inside I
    Sergeant:
  • 311 Answers
Yes hes right,but its not a ball bearing .its a bronze bushing.if not getting repaired .if was mine i would have no problem using till cant stand any more.God bless,tom
Posted on Jan 01, 2009
Frigidaire (glws1439fs1) top load washer
If your machine is old means may be brake shoe might be very closes joined make adjustment and correct it otherwise it is a bearing noise kindly replace the bearing along with washer
Dec 24, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Bearing problem on frigidaire gallery top load washer
Eventually the bearing will spew grease all over your load.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2009 | Washing Machines
Tub bearing is making grining noise
yes when the washer sounds like an airplane taking off during the spin cycle, it is a worn rear bearing.
it does happen from the wrong type of soap being used. the suds from regular soap will destroy the seal and allow water to get into the rear bearings causing the bearing to fail and become noisy.
HE type soaps have been recommended by the manufacturer for about 6-7 years now and you MUST use them to prevent this from happening. it can also happen with HE is you just use too much.
now the good news... the inner tub has a lifetime warranty but the outertub, comes with seals and bearings, may only have a 5 year part only warranty.
what you can do is to call frigidaire at the 800# and ask if they can check the warranty for you. a 3 year old and a 5 year old unit might be covered by a part warranty. if so then the labor to replace the tubs will be about 200-300 bucks. i know its a pricey repair but is certainly cheaper then buying a new washer.
by the way, all front load washers will do this if you use the wrong soap.
Dec 30, 2008 | Frigidaire GLTR1670A Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Loader Won't Drain
if your washer is digital or with elecronic control board check the the motor control board located at the bottom difiniely you have to call a tech to confirm that. other model like wd5595 and wd 8095 has the same problem and it is the motor control unit that always fails.
Mar 21, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
