Question about HP LaserJet 3330 All-In-One Printer
Scanner error Hi, I have HP Laser Jet 3330 all in one printer. they always come up said scanner error. it there any way to fix it? Thanks. Sandy
  • moose79 Jan 08, 2009
    I fixed it already. I just clean up the scaner film.
    when I turn it on I get "scanner error turn off turn on" message. I've turned it off and on..I've unplugged it from the wall and plugged it back in. I currently do not have it hooked to a computer, I just use it as a copier.
    The scanner bulb keeps moving to and fro until it display a message to turn of the printer with a sound warning.
    Cleaning the scanner mirror of my 6 year old HP 3310 solved this problem. Many thanks to jvgough for telling how to accomplish this with minimal disassembly. I was afraid of tearing up the belt, so used the on/off method of moving scanner; this process took about 15 cycles, so be patient. Dust on mirror was very fine, and looked like a film. Flashlight very helpful to see imporvement.
  • Anonymous Jan 22, 2009
    Hi I have the problem scanner error 6 turn off machine, any help please.
    Thanks
    Novelist:
  • 125 Answers
You will have to replace the scanner assembly.
HP Part # C9124-60103
This replacement shoult take 20 minutes.
Posted on Jan 08, 2009
Won't go to menu
Had a similar problem on a HP MFC3330
Fixed it with the following video aid:
"how to fix the scanner bulb warming up error hp 3330 or repair 3380 scanner bulb warm up problem - YouTube"
http://youtu.be/lqG_nmi3vC4
Hope it helps...
Jul 27, 2014 | Dell 1600n All-In-One Laser Printer
How do I fix a dark streak down center of scanned document on HP laser jet 3330
Lines and streaks are usually caused by ink or trash blocking the scanner pickup. You need to open the top of the scanner and clean the scanner glass. Here is a link to a guide that shows where to look for something blocking the sensor.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
May 07, 2012 | HP LaserJet 3330 All-In-One Printer
HP Laser Jet 3055 printer-52 scanner error?
Remove the top cover. The laser / unit is a black box.
Try www.partsurfer.hp.com
to purchase one.
Jan 15, 2010 | Office Equipment & Supplies
HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Sep 23, 2009 | HP LaserJet 3030 All-In-One Printer
52.00 error
Hp says you have a bad scanner unit(laser unit) or DC controller, but first reseat all your connectors on your scanner unit(laser) and DC controller. Your scanner is located under the top cover and the DC controller is located behind the right cover. If the problem still persist replace the scanner first.
Apr 23, 2009 | HP LaserJet 4350n Printer
Scanner Error power on power off
there is a sensor in the paper feeder tray which is also connected to the scanner area that sensor is bit moved from its orignal position or is slightly broken while the paper jam or while removing the paper jam.
please check the sensor.and make it proper.the error will go.
Oct 05, 2008 | HP LaserJet 3330 All-In-One Printer
Oct 02, 2008 | HP LaserJet 3330 All-In-One Printer
HP LASER JET 3330
Sounds like the scanner bulb mate. There is a post on here already about how to fix the scanner bulb problem.
Hope you fix it
Apr 05, 2008 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
236 people viewed this question
Ben Johnson
