Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Oven door not sealing?
The door just doesn't appear to close with enough force to keep it tight. I have to cookmost everything for 15-30 minutes longer the called for. Cookies themselves have to stay in for 5-7 min longer. I already replaced the seal but it still does not work right. Electrolux is useless. Any suggestions? I even tried closing the oven door with a peice of paper in the door. When the door is closed the paper pulls out with no resistence..telling me I have a bad seal.
  • ned7040 Jan 02, 2009
    Does the part where the piece of paper pulls out without resistance make sense? It should not do that correct?
    President:
  • 2,692 Answers
These doors have springs to shut them. If you can figure out how to get to the springs usually you will see that one is either unhooked or unattached at one end. If broken on the end bend another hook into it and add a pice of wire long enough to make up the broken difference.
Posted on Jan 01, 2009
  • Thomas F. Schneider Jan 02, 2009
    Correct; a piece of paper should not easily pull out, but you have to have a force on tha seal .Is the door easy to open? You can feel the seal and if it is still flexable and not torn is is likly ok. If it is stiff,then you are correct , it needs replacment.
The oven door will not close .
i just had a similar problem .the door would fall and i had to lift the top of my door hinge to close it .I found that the pin on the door hinge spring had fall.en out . I installed it back and now it works the way it should.the spring should feel tight with no movement.
Mar 25, 2014 | Dacor MCS130 Millennia Electric Single...
E305075FPSA HighSpeed Eletrolux the door appears to not be closing tight.
No! this not normal, I'am concerned about microwave leakage, and a 1/8 gap is to much, should be tight against the seal "major safety factor" the door is out of alignment or the bottom latch is not secure "to much play" I recommend a pro simply because he needs test for leakage when the door is properly fixed.
Mar 22, 2012 | Electrolux ICON Microwave Combination Oven
Oven door does not stay closed tight enough to keep light off or to keep open door light on heating
Sorry to read about your problem, I hope this helps you out.
you have a spring/hinge problem. or a small chance, your door seal is defective.
you may try to remove the door and re-seat it...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Whirlpool RBS305PD Electric Single Oven
Oven takes forever to heat up - its a thermador double oven - me272
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
Mar 17, 2010 | Thermador C272 Electric Double Oven
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
Kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
Dec 21, 2008 | KitchenAid Architect KBFA20ERSS Stainless...
Maytag Gemini Electric Oven - Lower is not locked, but will not open.
Usually, starting with a COLD oven, turn the self clean on. Wait 3 minutes, then turn it off [cancel] WAIT 1 minute at least, do not immediately pull on the door. This should reset the lock sync. If you cannot get it open still, you may have a faulty sensor that thinks the oven is overheated, or at this point you could have a bent actuator rod from all the tugging!
May 01, 2017 | Maytag MER6772 Gemini Electric Kitchen...
Oven door hinge replacement installation
kitchenaid superba oven door will not stay closed.
Oct 22, 2008 | Kitchen Ranges
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
499 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
