Question about Philips Magnavox DVD/VCR Dual Player
I want to copy my VHS tape to a DVD
Magnavox DVD Recorder /VCR ZV450MW8
  • feb041961 May 11, 2010
    it depends on the tape. some vhs tapes are designed to prevent copying because infringment laws there is nothing you can do except to make sure vhs tape is clear of copy laws. also on remote there is a button that indicates vhs to dvd make sure this is engaged
    Problem Solver:
  • 7 Answers
You should just have to hit the dubbing button on the front of the unit. Make sure you hit stop on both the vhs and the dvd sides. I found that in certain conditions it won't dub.
Posted on Jan 02, 2009
Lost manual for DVD Recorder/VCR ZV450MW8 Need instructions to copy DVD Disk to VDD Disk or e-mail manual
To dub a DVD, first press Setup on the remote. Then select Recording (use the Up/Down arrows and then press OK). Navigate to and select Dubbing Mode. Select the direction for the duplication. Then press Setup to leave the Setup menu. Then press DVD to ensure that the unit is ready to play the DVD. (Press VCR if you are dubbing a video tape.) Then Press Play to advance to the section that you wish to duplicate, if needed, and then press Pause. (Press Pause a bit early; the dubbing process will lose about 5 seconds.) Now, press the other Mode button (VCR if recording to tape, DVD if recording to DVD). Next press D.Dubbing on the recorder or the remote. (The button is to the right of the Channel Up/Down buttons on the recorder. It's near the bottom left on the remote.) Press Stop when the section to be duplicated has been played in its entirety.
The Magnavox ZV450MW8 was manufactured by Funai with the Magnavox name. Thus Funai Service has the manual available: http://www.funaiservice.com/manual2012_search2.php . The direct link is http://www.funaiservice.com/manuals/MAGNAVOX/ZV450MW8/ZV450MW8.pdf . The directions for dubbing a DVD to VCR or vice versa start on page 48. Note: copy protected items cannot be duplicated.
I hope this helps.
Dec 10, 2014 | Televison & Video
When I insert a vhs tape into the turned on Magnavox zv450mw8 recorder it then shuts off, what goes
There are many delicate nylon parts in VCR's, they are usually the first to break, that is one possibility. The covers come off these pretty easily but I would pick it up and shake it first to see if something is rattling around inside, if you can hear something moving around in there and if it isn't something a child pushed inside (this often happens) then it is probably toast as it is more expensive to have fixed than it is worth. One other thing that is possible is that there is buildup on the capstan or tape guide rollers which can be sticky and wrap the tape around themselves and the machine will kick the tape out. If you are at all handy you could take the cover off, (FIRST MAKING SURE IT IS UNPLUGGED), plug it back in and insert a tape. As you watch the tape you can see at which stage of the cycle the tape backs out and maybe see the problem. As you can see many problems are possible, best to get another machine.
Jun 03, 2014 | Magnavox ZV450MW8 DVD Recorder VCR
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vhs tape stuck in vcr
Some one needs to open it to see if the tape is loaded but wrapped around a post or tangled up.
What usually causes this is the mechanism that moves the tape has a problem---bad or broken belt or rubber drive wheel that moves tape is bad.
Its called eating tapes.
With it apart you may be able to extract the tape and then insert with it apart to see if reels etc are or are not moving in RR and FF first and then in play to see what is not moving.
May 26, 2012 | Magnavox ZV450MW8 DVD Recorder VCR
Need manual for Magnavox ZV450MW8
Hello
Get into this site from you can download the user manual of your device. It is in pdf format comes over 11MB capacity. If you feel any difficulty in downloading the same, send your email address to me by FixYa comment box. I;ll send a copy of the manual to you by return mail. OK.
www.funaiservice.com/manual/MAGNAVOX/Manual/ZV450MW8.pdf
Jun 24, 2011 | Magnavox ZV450MW8 DVD Recorder VCR
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
I just bought a Magnavox ZV450MW8A DVD/VCR Recorder. It has recording capabilities on both the DVD and VCR components but can you tell me if I can use it to record FROM the VCR directly onto the DVD? This...
Yes, you can, I have this unit and have actually copied a dvd to a vhs and then copied back to a dvd as I wanted a dvd copy to give a friend. The directions in the book are really quite simple. They tell you how to set the vhs to the spot where you want to start copying, etc.
I have not yet tried copying my family vhs tapes, but don't see a problem, just a big project. Good luck.
Jun 13, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox VCR/DVD recorder model ZV450mw8. VCR plays a tape for 6 seconds then shuts the whole unit down.
You will need a technical person to open the unit. This problem can be as simple as a dirty sensor, or bad tape drive parts, or burned out computer chip.
Feb 01, 2009 | Philips Magnavox DVD/VCR Dual Player
I need to get a manual for a magnavox vhs/dvd recorder item #zv450mw8
Hey jleedwards,
If you have lost your owner's manual for this Magnavox VHS/DVD recorder, you should be able to find a copy of it online through the Magnavox/Funai support website:
http://www.funai-corp.com/6pdf/om/ZV450MW8.pdf
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 16, 2008 | Televison & Video
Philips Magnavox DVD/VCR Dual Player Logo
204 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
