Draining problem with whirlpool washer
Let me start with I'm a commercial washer and dryer tech. I'm doing a favor for a friend and looking at there whirpool washer model number gsx9885jq0 catalyst. The washer agitates and spins but will not drain the water. The water is flowing through the pump but seems to not be getting through what looks like a secondary pump in the rear of the washer. I'm not familiar with this part and am not even sure what it is or is called. I'm thinking that either it isn't opening preventing the water from draining out or some thing is stuck in it. I took the hoses off to it and can't see anything obstructing the water flow so I'm at a lose as to what it could be.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
When I push the power button the start button flashes on and off and touching start does not start the machine.
Better call a certified Whirlpool appliance service shop and have a tech come look at it and possibly repair it.
Apr 08, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My whirlpool commercial washer is not draining properly. The close is extremely wet but there no excess water in the drum. what could cause this issue?
Sounds like the water drained but the drum did not spin. Select spin and see if the drum actualy turns. If you hear a motor running then it could be just the drive.
Oct 03, 2014 | Washing Machines
Whirlpool commercial top load coin washing machine with only Luke warm water
i would take hoses off washer and check screens infill valves first.valve may have a thermister in it to control water temp this may be bad.may have to call a tech.
Dec 10, 2013 | Whirlpool CAM2752RQ Coin Operated...
Kenmore washer 22632100- a couple of days ago, found a small black plastic ring object in with the washed cloths. It has small tongs that appear to provide a screen function. Looks like it was glued to the...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22632100&pathTaken=partSearch
I'd look at each of the diagrams in detail and try to determine which part it may be.
I'd also check the following Whirlpool / Kenmore Service manual for these washers as well as the Whirlpool parts list for their top load commercial washers (although the consumer models are basically the same.)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
What you're describing might be a Filter Plug that fits in the bottom of the basket. See Item # 12 in the Agitator / Basket/ Tub diagram.
As for the water draining out, it's possible that the drain hose is damaged or the end of it isn't above the water level.
I'd pull the cabinet to check the hoses and pump. See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=dbeec6bac84cc8c85fb6925ae94cb1cd
Apr 24, 2010 | Kenmore 22422 Top Load Washer
Hi I have an AWG 329 washer drier. The water won't
the pump is either broken or there is a block in the drain line sadly with these ne high tech units they can break down within weeks ive seen 3000 dollar washers and fridges writen off as quality test are very weak
Apr 21, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
My candy 514 is not draining properly - even after a spin cycle the clothes are still very wet suggesting that water is not getting out
I have a GE and my friend has the same problem with his whirlpool. Removed the frt cover adn looking at the washer on the left side there is a clean out drain. My kids leave things in pockets and filles this drain up and washer will not drain. it is very easy to do
Oct 26, 2009 | Candy CNW136 Front Load Washer/Dryer
Door lock error whirlpool duet front loader
DO NOT BYPASS A SWITCH UR HOUSE WILL BE FLOODED INS WILL NOT COVER IT. YOU NEED A DOOR LATCH, AN MMC AN PROB A BELLOWS CAUSE YOU WILL RUIN IT PUTTING THE SPRING CLAMP BACK ON. DO URSELF A FAVOR AN CALL A SERVICE TECH
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer Problem
cabiros dont have a wig wag switch check your drain pump for obstructions to find the right repairman go to www.whirlpool.com under support enter your zip code under find a service tech and they will give you a list of people in your area
Jul 07, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
