Question about Gateway Wireless-B Router (wbr-100)
I have a WRT54 G I have two computers hooked to it .. it must have got shut off or something because the only way i can get online is hooking directly to modem i have tried to reset the router by unhooking the power and pushing in on the reset button i cant get the router page up unless im hooked to router then im off line i have been tring for three days i callede once but could not understand the man from Indea
  • 3 Answers
First do a full reset by holding the reset button while power is applied. Wait until all the lights on the front panel go out and come back on.
If you can login to the webpage, download the latest firmware from the linksys website (or install a "hacked" FW like WWDRT or Tomato).
This should solve the issue, as long as the hardware has not failed. Over the last 7 years I have gone through 3 WRT54G's due to hardware failure; most of these were likely due to overheating issues on the wireless transceiver IC.
Posted on Jan 01, 2009
How to hook up android box to smart tv
You need to go to Radio Shack or Look up online; but buy a Auvio USB/HDMI PC to TV adapter and an HDMI cable at 6 to 12 feet long. Hook it up following the instructions in the kit or watch the video on to hook it up. You can hook up your phone or computer using this adapter. Have fun watching your videos then.
May 24, 2017 | Televison & Video
When turning dvd on the unit shuts off right away
Pretty common with that model. All you can do is try unplugging it for 10 minutes or so and try it again. If still bad, disconnect everything hooked to it and see if it stays on. If it does, hook up one item at a time to see if a speaker or something is causing the shutdown. If it doesn't stay on with nothing hooked to it, it has internal (possibly capacitors) that are bad.
Nov 29, 2013 | JVC TH-C60 System
Wireless router is not working
Go to Here for Linksys EasyLink Advisor (LELA). With this software you can monitor the routers status and troubleshoot.
Most trouble shooting involves disconnecting the power to the cable modem and the wrt54 router for about 10-20 seconds. Then plug in the modem until it lights, then plug in the router. The Advisor will then get a new address.
It also shows a graphic picture of your whole system.
I have a wrt54 and use this whenever I have a problem. I fix it then turn it off.
Hope this helps.
Good Luck
Feb 19, 2010 | Linksys Wireless-G WRT54GS Router...
Cannot access the internet through the router. Seems like the router and the modem are not communicating. When I bypass the router there is no problem.
make sure the router does not have the same ip address as the modem. change the last on the router to
Jan 09, 2010 | Linksys Wireless-G WRT54G Router
Windows Vista Internet Connection problem
Are you on the wireless internet or on the internet through a cat5 cable? If on through the wireless I think its a wouter issue. try upgrading the firmware of your router first. If that doesn't work try using a different router. Also try upgrading your drivers on your computer for however you are connecting to the internet. Either your network card or your wireless card via device manager.One of those solutions should solve the problem.
Sep 12, 2009 | Computers & Internet
I have a 1992 eagle talon tsi im trying to hook up stereo
there is a "remote" wire that turns it on-sounds like you hooked it up to your lights. It needs to be hooked-up to the ignition so your radio turns off and on with the engine. Your power wire can go to the battery if you absolutely can't figure out which 1 it is that old radio used, but the remote wire must be hooked up right to turn it off so you don't leave it on and run the battery down.
Aug 31, 2009 | Car Audio & Video
Cannot complete downloads
when you say that everything works when the router is NOT hooked up to the PC, does that mean that you have the DSL modem connected directly to the computer?
then, when you hook up the router, you're connecting it BETWEEN the DSL modem and your computer?
You probably need to log in to your router and set it up to connect through the DSL modem to the internet: it may not do it automatically.
is this computer running windows XP?
if so, go to control panel, then network connections.
if you double click on the local area connection, and go to the support tab, it should list something like this:
Address type: assigned by DHCP
IP address:
Default gateway:
Try opening internet explorer, and typing in the numbers it lists for default gateway.  hopefully, that will bring up the configuration screen for your router.
Mar 26, 2008 | Computers & Internet
Gateway Wireless-B Router (wbr-100) Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
