Question about Frigidaire PLD4375RFC Dishwasher
6 mo. old frigidaire d/w displays the "ER clean S" flashing error
Model number PLD4375rfc
  • shanelleengl May 11, 2010
    So what does that mean?
Probably a control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually.
Posted on Apr 08, 2009
  • Leslie Mac
    Leslie Mac Dec 11, 2013
    So, is it worth it to fix it ? Mine is 5 yrs. old and I have to pay $75.00 to come out , and parts / labor ... UUGGGHHHH
Frigidire pld4375rfc2 display says er
I rough guess is that there is moisture build up in the air vent causing the controller to fail. This could be due to not enough gap between the dishwasher console and the kitchen benchtop.
Not sure how long you have had the dishwasher, but a check might be handy.
Refer installation inststructions in particular about the use of the cabinet seal kit.
Aug 17, 2012 | Frigidaire PLD4375RFC Dishwasher
I have a Frigidaire model#PLD4555RFCO the er code and the washing and drying and clean and S lights are on and blinking on the display. have any ideas what the problem is?
Hi
"Er Clean S" is a common error with Frigidaire which means shorted keypad. The issue is with the touchpad/keypad that should be replaced. However, before replacing the keypad you can unplug it and take it apart completely and use a hair dryer to blow some warm air on the keypad assembly to blow the moisture off. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Frigidaire Professional Series 24 in....
Error message "clean S"; flashing
Hi
Daniel
Jun 18, 2011 | Frigidaire PLD4375RFC Dishwasher
Error codes flashing
Hi, This is mainly due to control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually..
Apr 13, 2010 | Frigidaire PLD4375RFC Dishwasher
I have a PLD4375RFC DISHWASHER WILL NOT RUN P F FLASHES AFTER ABOUT 2-3 MIN. it will start and run for 2-3 min.before the power failure unit less then one year old
Sounds like a faulty console panel. They had a problem with moisture getting into it, and causing it to get a PF (power failure) code. If it's under 1yr old, it should still be covered by manufacturers warranty. Part number for console with touchpads is 154639207, failing that, i'd say you have a bad control board, but console much more likely.
Mar 31, 2010 | Frigidaire PLD4375RFC Dishwasher
Our dishwasher is making a grinding noice coming from the pump. We have had it about 18 mo. Model number PLD4375RFC. Thanks
Check to see if it level, belt tension, or if play in the motor bearings. If so, need replacing.
Jan 06, 2010 | Frigidaire PLD4375RFC Dishwasher
4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Oct 03, 2009 | Frigidaire PLD4375RFC Dishwasher
Error flashing and won't reset.
hi there,
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
Oct 02, 2008 | Frigidaire 24 in. PLD3465REC Stainless...
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire PLD4375RFC Dishwasher Logo
1,132 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
