Question about Pioneer SD-532HD5 53" Rear Projection Television
Had an electrical power failure during a storm when we lost power
Tv did make a noise but not a very loud one, only seconds later, power was restored and the tv now will power on and then go into standby....We purchased this TV in Jan 2001, we plan on checking the fuses, anything else we should look for before calling in someone
Thank You Very Much and Happy New Year !
Martha
  • mmojave Jan 02, 2009
    We plan to...thank you, just good to hear from other owners that have had similar issues, and being the holiday when this happened did not want to bother our TV guy
    Problem Solver:
  • 4 Answers
There are no problem with the fuse if the pwer turns on then off ,,you should get some one to look at it ..unless you have electronic experience....hope this helps ..
Posted on Jan 01, 2009
Freezer making loud buzzing noise when turned on. We had storm and lost power sounds like its coming from on and off switch
the power grid may not be up to full power
happens after a power up every electric unit left on in the grid
on a storm all kick in in a massive load
turn off at the wall
unplug
plug back in
see if compressor startup again
Oct 15, 2016 | Refrigerators
Unknown to me BT had a major problem with vision box when I switched on TV at socket seconds later there was a loud bang and sparks. My TV is now NOT working
Sounds like something failed in the BT and caused major electrical discharge. With that your lucky only your TV was lost. That could have caused a full blown house fire.
Aug 07, 2016 | Samsung Electronics UN26EH4000 - 26in...
Tv was surged via hdmi by electrical storm. The tv appears to power on and then shuts off within 4-5 seconds. The screen looks as though it is turning on during this process, but doesnt stay lit long...
Unplug tv and cable box.Replug both about an hour later.Still have the same problems.The power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
Aug 13, 2010 | LG 50PS60 50 in. Plasma HDTV
The screen blanks out after approximately 20 minutes.
The power supply board is dead.Those high voltage transformers on the power supply board,one those power coil have a short in it,that why it cause this shutdown a have a loud electrical current noises.Tries websites like Shopjimmy.com.Ebay.com to buy a new refurbish power supply board for the replacement,should solved this loud electrical noises shutdown to tv.
Jul 10, 2010 | Sony BRAVIA KDL-40V3000 Television
Power went out during electrical storm. tv never
it is problem power supply some of components are demage such as capacitor or diod is bad. You go to a service centre and repear it by a good technician
Nov 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Power but no picture or sound
Actually, it seems the the ballast might have got damaged. This seems more like a ballast issue, it's easy to fix, plus ballasts run around 60 dlls.
Aug 10, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Accurian 3223 clock works and it powers on with "HELLO" displayed
Try unpluging for 5 min..return plug...push and hold power button for15 seconds this should reset it!hope this helps!
Dec 12, 2008 | Radio Shack Accurian ADR-3223
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Jun 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Pioneer SD-532HD5 53" Rear Projection Television Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
