Question about HP Officejet 7130 All-In-One InkJet Printer
Printer copies come out blank
My hp officejet 7130 all-in-one worked for a short time but started having problems. I just tried to use it again, it asked for new ink which I loaded. It goes through all the correct motions but the paper comes out blank.
  • incarnateinc Jan 05, 2009
    i have the same problem.
    ever since i upgraded to vista, replaced all printheads and bought a ton of expensive ink cartridges.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
HOW DO YOU REMOVE THE GLASS ON A HP OFFICEJET 7130 PRINTER I HAVE REMOVED THE SCREWS BUT THE COVER WON'T COME OFF.
Gene,
There are a couple of "hidden" attachment points which hold down the top bezel and glass. You can see step-by-step photos on disassembly of the scan bed that will show right where they are at http://www.fatrcat.com/hp7100/scan_head.html
Mar 22, 2012 | HP Officejet 7130 All-In-One InkJet...
Problem for HP Officejet 7130 All-In-One InkJet Printer tells me to close ink cartidge and its CLOSED! Thanks
The full-featured HP OfficeJet 7130 all-in-one offers photo printing, double-sided printing, an automatic document feeder (ADF), a fax, a scanner, a copier, and inputs for all of the current breeds of photo memory cards on the market today. At first blush, the machine's large footprint may seem overbearing--until you take into account just how much space you're saving by putting all of your technological eggs into one basket. Unfortunately, the 7130 isn'
Jul 16, 2010 | HP Officejet 7130 All-In-One InkJet...
When printing or copying, I just get blank sheets
You may need to clean the printer heads. First try going to your printers properties and you should have an option via troubleshooting to clean, if this does not help, look inside the printer depending on the model, near the cartridge, you'll find where the ink comes out. Take a damp qtip and wipe them good. They are most likely clogged. I cleaned mine with alcohol but I'm also a risk taker :). Hope this helps!
Mar 09, 2010 | HP Officejet 7130 All-In-One InkJet...
Computer does not recognize Hp 7130 printer
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Jul 02, 2009 | HP Officejet 7130 All-In-One InkJet...
I keep getting a scanner failure error
Let's try this. Turn power off, unplug the cord from the surge strip or wall socket. Leave unplugged for about 30 minutes, then plug back in and turn on. Hopefully this will fix your problem. Good luck.
Mar 19, 2009 | HP OfficeJet 7130 All-In-One Printer
Supply expired
I have an HP Officejet d145 and had the same problem. The short solution is to extract the little battery they keep hidden inside it for about half an hour, and then replace it. Worked for me!!
explained in detail here: /www.barplan.com/blog/home/2007/07/16/supply-expired-hp-printer-ink-expiration-scam/
good luck!
Sep 21, 2008 | HP Officejet 7130 All-In-One InkJet...
7130 will not print
Try # and 6 and shutdown. Whe you restart it should be reset.
Jul 02, 2008 | HP Officejet 7130 All-In-One InkJet...
HP Officejet 7130 xi all in one say Bad Print Head
printer flashes lightes and instructs to turn off and on. When ask to print
Apr 06, 2008 | HP Officejet 7130 All-In-One InkJet...
Officejet 7130 problem with scan
Try cleaning the white calibration strip under the scanning glass (requires technical knowledge).
Try this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01150111&lc=en&cc=us&dlc=en&product=91466&rule=23549&lang=en
Dec 28, 2007 | HP Officejet 7130 All-In-One InkJet...
HP Officejet 7130 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
