Question about Seagate Computers & Internet
Hard drive reported at zero bytes
In sea tools is only place hard drive detected at 120 gb every where else reads zero. device manager detects 0 gb hard drive but drive not detected during windows loading. Data already gone need help to reidentify at full capacity. so i can install new partition and reload drive.
See after teh utility named Partition Magic, It will solve these typoe of errors. Another cheap option is to try to format it with a vintage computes BIOS, HDD Formattion option, Not available in newer BIOS.
Tyr aldo Fdisk /mbr in the DOS PROMPT , booting with D.O.S. Ver. 6.0 Anyone remember this Operating system?
And the last option is to format the drive undel LINUX and thern get it back to Windows XP.
Posted on Jan 03, 2009
Mirco SD card shows free space 0 bytes and used space 0 bytes
Click on the drive and then in windows select tools then folder options, then view and select or unselect hidden files or folders, plus hide protected files.
This should show all files on the card.
The only other thing I can think of is that the camera uses a different format to Windows. So it can't read the card.
Jun 07, 2017 | SanDisk Electronics - Others
Hello, I have a Sandisk Cruzer edge 4gb usb device Now it detected that used space 0 byte free space 0 byte please fixe my probleme. Imamul hazari from wb india imamul.hazari1976gmail.com
click start click on computer to open then you should see your usb drive right click select properties tools check now tick in both boxes start to check for and attempt recovery of any bad files and bad secors on your usb drive you should not have any input while the chkdsk utility is attempting a repair any input might damage this drive
hope this helps
Jul 26, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Storejet problem
Good day!
1. Go to my computer and right click then click manage, go to disk management and see if your external harddisk is showed.If showed,then you can see the options there to manipulate your harddisk, either you format it or repartition.
2. You can use also a disk manager software to fully control the function.
Jul 06, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
ST3250820A - hard disk locked
Get a dos program called F-disk ... put the floppy into your floppy drive and boot your computer. Delete the partitian, format the drive and you will be good to go.
Maybe you can use the software that came with the Seagate ... if not, you can download it at Seagate.
Apr 21, 2010 | Seagate ST3250820A 250 GB EIDE Hard Drive
Hard drive detection
there must be some problem with the firmware,you need to update your fw or you can use some tool to restore your fw,such as pc3000 or HD Doctor for salvationdata
Apr 20, 2009 | Toshiba 120GB USB 2.0 Portable External...
My simpletech 120 gb hard disk is not detecting over my pc what to do?
right click on my computer --> manage --> disk management
does it detect there ?
Also what about in device manager ( right click on my computer --> properties --> hardware tab --> device manager
Apr 17, 2009 | SimpleTech (STUU2F35120) 120 GB Hard Drive
Transcend 1 GB removeable Pen drive is not detected
The pen driver is ifected with virus.Just format it with CMD and ur problem will be solved
Nov 01, 2007 | Transcend (589307) Media
Computers & Internet Logo
250 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
