Question about Hotpoint 18 in. DC28 Slim-Line Built-in Dishwasher
Dishwasher emptying When turned on, the rinse light flashes and sounds like it is trying to empty all the time and does not continue the cycle
  • Anonymous Sep 27, 2008
    will not empty
    President:
  • 1,462 Answers
Check the base of the machine and see if it has water in it. if so, this will cause the dishwawsher to pump out all the time. mop out and it shoiuld run. you have a leak and will have to trace it - not always easy
Posted on May 08, 2007
The last few times I filled the rinse dispenser and ran the dishwasher I notice the arrow showing the rinse aid is almost empty. Impossible. What is going on with this?
THE ANSWER IS YES. FROM YOUR DESCRIPTION IT SOUNDS LIKE THE DISPENSER PUMP OR RESERVOIR IS LEAKING. YOU NEED TO REPLACE THE WHOLE SOAP DISPENSER. ALTHOUGH DISH WASHERS NEED THE HELP OF RINSE AID IT IS ONLY DISPENSED A DROP OR TWO AT A TIME DURING THE FINAL RINSE CYCLE PART OF THE WASH. HOPE THIS HELPS AND THANK YOU FOR READING THIS.
Oct 07, 2014 | KitchenAid Dishwashers
Hotpoint BC1450 Light 2 normal flashes
Flashing lights, pump running even when turned off. Had to switch off at the socket. The vibration from the machine had managed to give a quarter turn to the appliance gate valve, the type with the little blue handle. I could see the indentation in the rear rubber panel on the back of the dishwasher. Unscrewed the little blue handle, pushed the machine back in and started working as normal. :)
Oct 07, 2012 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Dishwasher does not wash simply beeps continously and wont start the rinse cycle with green flashing pre rinse light. Have tried turning off at power and have checked all connecting pipes. Have emptied...
If your dishwasher is a whirlpool or IKEA then maybe the answer given by emmanuelr in "Whirlpool dishwasher ADP5962 F7 error code" may do the trick. It certainly worked for me. Bit technical but if you are happy taking the sidepanels off the thing then the fix may be easy.
Apr 06, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Cda cw494 dishwasher it runs for about 20 mins
is the light indicator flashing because you need to add salt or rinse aid.i have a bosch and my lights only flash to give me information on addig salt and,or rinse aid. so i can stop this by setting my dishwasher to take all in one detergent ,then the lights will not flash.
Nov 10, 2009 | Dishwashers
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
FDW40
This is a blocked pump,Strip down pump and remove blockage.
Jul 24, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch dishwasher SHU66C02UC - Rinse Agent issue
Does soap draw open at right time?
Same solenoid opens soap draw as injects rinse aid.
Turn up hardness counter ?
Any blockages in dispenser unit its-self?
OTHERWISE CALL IN THE PROFFESIONALS !
Apr 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
FDW60 Fast and Delicate Lights Flash
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Mar 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 18 in. DC28 Slim-Line Built-in Dishwasher Logo
107 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
