Question about Zanussi FJS1225W Front Load Washer
Blowing fuse,caused by dripping water?
Hi,my machine has started blowing fuses,they are the right ones - 13Amp,brown. I have looked under the machine,and it looks like its got some water dripping onto the long box at the bottom,(the box has a pipe from the Fluff filter, and from the drum). Even though the two contacts have a 'plastic sheet' covering them,I've noticed some water under the sheet which is making the fuse blow,when its turned on. I think its coming from an approx 4 inch square part,(possibly the pump??),as it seems to be slowly leaking from its seam,and this peice is above the 'pole' which is blowing.It is 'black' around the base of the 'pole connection',where the wetness is. Can anyone help please? As its a great machine,and is/was super reliable! Thank you :)
  • Terry Gee
    Terry Gee May 18, 2007
    The fuse still blows when the machine is dry,and the 'blow' seems to come from the black pole on that long box,as there are 'blow marks' around the terminal pole!
    I hope my machine does not have to go to the tip,as its a super machine...used every couple of days,and untill now,very very reliable!
    Any new ideas please?
    Thank you :)
    President:
  • 1,462 Answers
Dry out the area thoroughly and restart the machine to see if fuse blows with it dry - i'm not convinced this is the cause. the part you are referring to i think is the drain pump and these do lewak sometimes. the other place to look is at the door boot which if it is holed can cause water to drip down in the same area
Posted on May 08, 2007
My machine fills with water and before the drum starts to rotate, it blows the fuse.
If your talking about tripping the breaker its designed to trip under load. Yes if something is keeping the drum from turning that put a load on the breaker and trips it..It will keep tripping until there's no over load on the drum...I'm guessing your talking about a washing machine... You can take the belt off the motor and if the motor is good it will turn on but not spin the drum...Then you know the motor is good and something is preventing the drum from turning. And if the motor is bad you can smell a burnt smell if you get close enough to the motor..Hope this helps
Jul 01, 2017 | Washing Machines
My d27105 is blowing the 13amp fuse in the plug ?
If it continue to do it the machine had a "short circuit".So inspect the machine and look for any brake cable the is touch any metal part of it.
Nov 09, 2010 | Dewalt DW746X 10" woodworker's table saw...
Location of fuse in fisher& paykel washing machine
Fuse is tiny round redish brown thing bout the diameter of a pen.non replaceable in later models,Grey boards & Brown boards.they are soldered in & in most cases other damage is caused when they blow,I don't know why they even bother putting one in.
Earlier models such as Blue,Yellow & Green boards have a glass fuse you can replace but like i said before the minute you put a new one in & turn it on they blow straight away because there is other damage caused when it blew the first time,but some times it actually works.
May 22, 2010 | Fisher and Paykel Washing Machines
Blown fuses
please check your fuse box, it must have 22amps fuse. if not than upgrade it.
if your fuse is of 22amps or above, than my friend you have to replace your switch...............thank you and have a nice day
May 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Sanyo EMS1000 microwave. Keeps blowing 13amp plug fuse.
New or older wiring to microwave? Is there a GFI circuit installed?
Apr 27, 2009 | Maytag MMC5000 Microwave Oven
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
92 cadillac deville a/c blows fuse
The conector for the a/c compressor comes with a diode that keeps power from returning after the compressor cycles off. Check or replace the connector/and or diode and see if that fixes the problem
May 18, 2008 | 1992 Cadillac DeVille
Blowing Fuses....
it may be the water inlet valve has expired? use an ohmmeter to check when powered down
May 18, 2007 | Zanussi F1245W Front Load Washer
Washing machine blown fuses
Hi - had a similar problem with about 3 different makes of washing machine - the RCD switch on the main household fuse box was continually tripping . Nobody could give me a right answer . Eventually ended up with a Hotpoint . Felt sorry for the delivery guys from the electrical retailers having to keep dragging machines in and out .
May 07, 2007 | Indesit WA 115 Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
