Question about Kenmore 15129 Built-in Dishwasher
How to take apart the diswasher to clean it - Kenmore 15129 Built-in Dishwasher
  • 9 Answers
This is a 5 step process.
1 Remove bottom basket. Remove top basket (Pop off 'keepers' at the ends of the slidding shelf supports).
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly out.
3. Remove overhear conduit. There is one screw at the back and one at the top (Philips #2 bit). Rotate the whole assembly 45 deg right (Clockwise) and lift off of the centre post. It can be taken apart to clean.
4.Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift the whole plastic assembly out. Pop off the screen (Flat blade screwdriver around the edge) and clean.
5. Remove cap over cutter/chopper. There is a single screw at the front left (Under center assembly just removed). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter & filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc up. Clean thoroughly. Run a 'quick rinse' cycle with everything out, to clean the inside.
Reassemble.
Posted on Jan 02, 2009
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
We have a Kitchen Aid dishwasher model number KUDK03CTSS3. It's only about 3 years old, but the dishes on the top rack do not get clean. We thought maybe it was water not coming out the top, or food stuck...
had a simular problem, used product called dishwasher magic to clean it well and that took care of it. I got it @ walmart in the diswasher detergent area. Also be sure you are loading according to the manual. I now use lemi shine in every load for spot free clean dishes and put the dishwasher magic in it about every few months to keep it from getting build up. If you have a manual they have directions to take them apart for cleaning and I have had to that before to. Just remember how to get it back together. That's all I have but I'm not a repair person I'm a nurse.
Sep 15, 2010 | Dishwashers
My diswasher only washes at the top of diswasher.would we have pressed a button for this to happeren or is there another reason many thanks
Try cleaning the water jet openings on the propellar inside of the dishwasher. These small openings get clogged with food
Jun 16, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Early in the wash cycle, my Bosch diswasher makes a chirping soun
yes the problem from the heater.
if the sound coming from boiler heater means
1)scaling on the boiler tank(tank to be cleaned).
2)check any loose connection on the heater wire.
Jan 09, 2010 | Bosch Dishwashers
Dishes are not getting clean, detergent just runs down the door used tablets they worked until lately. The door would open but the tablet would not disolve. Now I use liquid but it just runs down the door...
Quickest way to ruin a good dishwasher is to use tablets. They have times when they don't brake down in the water like they were designed. Chance are that you used the tablets with the thin film package, this thin film gets caught in the pump and shut down water circulation. Have a qualified tech pull motor assembly apart for you and clean.
Nov 12, 2009 | GE Nautilus 24" Built-in Dishwasher
4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Oct 03, 2009 | Frigidaire PLD4375RFC Dishwasher
The clean light is blinking diswasher won't start
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Sep 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dirty dishes on lower rack
Please confirm that you own an LG LDF7811 dishwasher and it is not cleaning properly.
-Are you getting any error codes displayed? -Did you remove the mesh filter and clean any debris beneath it plus rinse out the filter itself?
-Are you using a name brand diswashing powder? Avoid ultra-cheap detergent, especially in water-conserving units like the LG 7811. Never use DW gel or tablets in any dishwasher.
-Do not over rinse the dishes before placing them in the DW. The food granules actually are used to clean all the dishes before being rinsed away.
Please try these suggestions and reply to this message with what worked best and if the problem continues. Good Luck!
Aug 25, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Kenmore 15129 Built-in Dishwasher Logo
349 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
