Question about Hampton Bay 48 In. Palm Beach in Textured White Fan
What do i do with the rubber stoppers for the blade assembly
  • 37 Answers
Those rubber "washers" get pressed into the holes in the blade itself. It takes a little bit of squeezing and manipulating though. Make sure they are fully in.
Posted on Jan 30, 2009
I can not open my "key fob" to replace the battery, does anyone know how to open it?
hey,, There are hidden clips inside you just need to pry it apart... some of them the back cover slides off, but most just pry apart. Look at the back and make sure there are no screws and no hidden screws (like those under rubber stoppers, the stoppers must be removed to expose them).. any way once thats verified, simply insert a flat head (blade) screw driver in between the seems and pry it apart.
Dec 28, 2012 | Cars & Trucks
The rear window wiper blade holder is rusted how do I remove it for replacement?
Three things you can replace depend on your budet
1) you can replace whole wiper blabe assembly by lift up the cover at the bottom end of the bale assembly and un-screw the nut and raplace whole assembly with arm , wiper insert etc ... with the new one This way cost you more.
2) on hte middle of the whole wiper blade assy has the flexible section, you can un-screw 2 small philipe pan head screw with screw driver and disconnect the top section with the wiper blade insert (rubber)
3) slide wiper blade insert out of the holder, becareful with 2 small steel blade will hole your rubber insert inside the wiper frame. Slide new rubber insert in the frame .
Feb 25, 2011 | 1995 Toyota Supra
Missing rear axle. is there a way to replace? the company won't.
I had the same problem. I bought this scooter for my daughter at a flea market and the rear axle was gone, someone had tried to fix it with a bolt, but it was very unstable. Here is what I did and it has seemed to work well. This will cost you less that 10.00 at your nearest home improvement store.
You will need
1x - 5/16 x 8 hex bolt 1x - 5/16 nut 4x - 5/16 x 1 1/4 flat washers 2x - 1 1/4 hard rubber stoppers 1x - 3/8 drill bit & drill 1x - gorilla glue or lock tight
Ok... before we start let me tell you what all this is for and how it works. The way I assembled this was, hex bolt, 1 washer, wheel for scooter, 1 washer, 1 rubber stopper (Insert this into the metal tube on the back of the scooter, so that on the other side you will just have a bolt sticking thru) now, 1x rubber stopper, 1x washer, other scooter wheel, 1x washer, hex nut.
The rubber stoppers are the hardest part and the reason for them is to keep the bolt going thru the middle of the axle tube. This will help to eliminate the scooter from wobbling.
Now, if you have read this far here is how we did it in order.
1. Take both rubber stoppers and trim them with a kitchen knife so that they will fit into the metal tube on the back of the scooter securely. (do not push them all the way in yet)
2. Drill a hole thru the middle of both trimmed rubber stoppers with the drill and bit
3. Take your hex bolt and slide a washer on
4. Slide your 1st wheel on
5. Slide on a 2nd washer
6. push on the trimmed rubber stopper to where it meets the washer. (The wheel should be able to still spin pretty freely, If you think it is to tight just pull the rubber stopper up a bit)
7. Take this assembly and push it into one side of the metal tube on the back of the scooter (you want the rubber stopper to be and flush with the edge of the metal tube and you can)
8. Your hex bolt will be stick out of the other end of the tube, slide on the last rubber stopper try and work it into the tube as best you can.
9. slide on 3rd washer
10. Slide on last wheel
*At this point I put the scooter on its side and pushed down on the wheel to force the stopper into the tube
11. slide on 4th washer
12. screw on nut
*Now I found that if you put the nut on to tight the wheels would not turn, but if you left it loose it would fall off.
13. To fix the above issue we put some gorilla glue on the bolt threads and screwed the nut on, we would spin the back wheels until we were happy with the amount of tension on the wheel. We then put some more glue on the top of the nut to help hold it in place.
14. Let the glue dry
Thats how I fixed my daughters scooter. I am in NO WAY a professional or expert at this stuff. Just a dad trying to make his baby happy. Hope this works for you!
Jan 26, 2011 | Bravo Dora the Explorer 3 Wheel Scooter
How do I change the rear turn signal bulb on my 2007 pontiac g6 convertible
Probably too late for you, but others may benefit as I just did this.
In your trunk on each rear side panel, you will find several rubber stoppers approximately 1" wide. take a flat head screwdriver and pry underneath to loosen then pull the stopper out.
Take a socket set you and find the right size socket for your nut and take out the 2 nuts on top and the bolt at the bottom (my bottom bolt didn't have a stopper on it).
Pull out the tail light assembly. Remove the bad bulb from the back of the assembly and replace with a new bulb (look up type of bulb to buy in your owners manual). Replace hardware and test lights.
Dec 26, 2010 | 2007 Pontiac G6 GT Convertible
It leaks from under the front door, escpecially when it gets to the rinse cycle. LG LDS5811WW
The Vent Kit behind the lower door panel, upper left corner has a rubber, solonoid stopper. Pressure from the spray arms overcome the rubber as the stopper hardens over time, allowing water to enter into the vent blower assembly. I found my replacement on Sears-Parts for $40 w/ shipping and just ordered it today. Be sure to turn off the breaker to the washer before removing the lower front door panel - 120vac in there, don't want no electricutions.
Oct 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
How to replace the wiper insert at the back of
  1. REMOVE RR WIPER BLADE
    1. Raise the rear wiper blade to the position as shown in the illustration where the meshing of the claw disengages with a clicking sound. NOTE: Be careful not to break the claw.
    2. Pull straight the rear wiper blade to vehicle's left from the wiper arm. NOTE: Do not fold the rear wiper arm with the rear wiper blade removed from it.1722d05.gif
  1. REMOVE REAR WIPER RUBBER
    1. Place the rear wiper with the rear end of the rubber protruded from the blade stopper as shown in the illustration. NOTE: Do not pull out the wiper rubber forcibly, as the backing plates will become deformed or the blade claws will become damaged. HINT: The rubber can be easily pulled out by pushing the middle area of the blade.
  1. INSTALL REAR WIPER RUBBER
    1. Install the 2 wiper rubber backing plates to the rear wiper rubber. NOTE: Be careful to observe and keep direction of curvature for correct replacement.
b. Insert the rear wiper rubber from the claw of the middle of the rear wiper blade into the rear end position.
c. After passing the rear wiper rubber through the rear end side claw, protrude it from the rear end stopper and pass it through the front tip side claw.
Sep 12, 2009 | 2005 Toyota Matrix
Gas tube came out of gas tank
If the rubber stopper is still plugged into the tank pry it out go to a small engine shop and buy new gas line.Thread the new line into rubber stopper to poper length,plug filter (new)on end that is going in tank then pop he rubber stopper back into the tank body.Have done hundreds and it isn't hard,you may need sone WD 40 on stopper to thread line and popping stopper back in .Good Luck
Jul 19, 2009 | Homelite Mighty Lite Lawn Trimmer
Valve Stem Assembly for Hoover Steam Vac
Put the rubber seal on the bucket first, then put the spring on the valve stem, slip into the hard collar, then push it into the opening in the seal, it will snap into place.
Dec 29, 2007 | Vacuums
Valve stem assembly
Hampton Bay 48 In. Palm Beach in Textured White Fan Logo
131 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
