Question about Panasonic DMR-E75V DVD Player/VCR
No video output when played on vhs
Blue back appears when viewing VHS tapes; otherwise, no picture at all. The tapes are not damaged, and the DVD player in the unit functions well. Am I able to fix the VHS problem?
Thank you for any help you can give me.
    Problem Solver:
  • 4 Answers
Try cleaning the cylender head of your vcr you can do that by opening the unit or buying vhs vcr casset cleaner....
ps : check if you have to switch between tv and vcr via remote , and when you insert the vhs tape you are able to rew and frw and press play normally...if these are ok usually its a little dirt onthe cylender head....hope this helps...
Posted on Jan 01, 2009
  • sifiguy2002 Jan 01, 2009
    try cleaning the cylender head of your vcr you can do that by opening the unit or buying vhs vcr casset cleaner....
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
I have a number of VHS-C tapes from my various video cameras in the early-to-mid 1990s that I'm transferring to DVD via my DVD/VCR combo device. But several of of these tapes that have the suffix...
VHS-C and S VHS-C are two different animals. Super VHS-C will have much better video resolution than standard VHS and uses better videotape. A standard VCR will not play the Super format. You need a S VHS VCR. You would need not only a S VHS VCR but also a S VHS-C adapter. Yes, Not even the adapter is the same as a standard VHS-C adapter cassette.
You can send out your few S VHS-C tapes to a video conversion service. That might be the least expensive way to get them on DVD. Otherwise you could look on E-Bay.com for either a compatible camcorder (S VHS-C) or the S VHS VCR and the S VHS-C adapter.
http://vhs-to-dvd.com is one video conversion service that should be able to get your tapes on DVD for you. You could also look locally for a video service that does conversions to DVD.
Feb 19, 2011 | Televison & Video
VHS Video Tape - Picture Roll.
Picture roll is caused by the frame rate being out of sync with the play back device. If the tape was recorded at say 25 f/m and is being played back at 26f/m. If you can, adjust the frame rate until the picture stands still.
Mar 30, 2010 | Philips VRX242AT VCR
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Vhs picture problem
Dear Zepp,
Firstly, video is not a clear as DVD.
Suggestions:
Do the video heads need cleaning?
Is the video tape a bit worn?, Try another video tape.
Do the video tracking controls needs tweaking?
Aug 09, 2008 | Samsung DVD-V4600 DVD Player/VCR
Panasonic PV-7451 VHS
I don't recognize your first problem.  The "light to dark" issue I believe is intentionally engineered (mine does it too); it prevents recording DVDs on to tape.  Try running the DVD player directly to the TV.  Radio Shack used to have a box that would correct this issue too, you might check there.
T. R.
May 18, 2008 | Panasonic PV-7451 VHS VCR
Cannot play VHS
Combo DVD/VCR players don't output the VHS with Component Video. Most of the time, it won't output over the S-Video either. The high end outputs are ONLY for DVD output. You must run a yellow wire, or use coax cable to get the video. Same goes for the optical digital sound out. It's only for DVD use.
Feb 28, 2008 | Samsung DVD-V6700 DVD Player/VCR
Panasonic DMR-E75V DVD Player/VCR Logo
161 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
