Question about NetGear WGT624 Wireless Router
Change NAT to open
I am trying to change my NAT settings from strict to open so that I can play Xbox Live more efficiently, but I only want to change this on my xbox and not on my computer. Help? my NAT is strict and kicks me out alot, can someone help
    Problem Solver:
  • 3 Answers
I’m not going to go into too much detail on what your NAT is or why it should be open, but in short, if your NAT isn’t open, you will have a hard time finding games, and it won’t let you join a friends party half of the time. So lets fix this problem.
  1. Go to your computer, and get to Network Connections. To do this, you will click on the start menu, and go to “My Network Places”. Once you get there, click on “view network connections” to the right in the Network tasks box. If your computer is hooked up directly to the router, you will be using the Local Area Network, and if you are wireless, you will be using the Wireless Area Network
  2. Right click on your connection, and then go to “Status.” If you are using XP, click the “Support” tab at the top. If you are running Vista, you will need to click the button that says “Details.”
  3. After you click on “Details” or “Support”, look for and copy down the Default Gateway, and the Subnet Mask. You will need this later.
  4. Close this out, and go to your 360 dashboard. Go to the system blade at the very end of the dashboard, and go to Network settings.
  5. Go down to Edit Settings. Change your IP address settings from Automatic to Manual.
  6. Depending on what your default gateway was, you may have different settings than mine.
  7. For IP Address, enter your default gateway. Instead of one digit for the last number, you will need to change it to something such as 109.
  8. Enter the Subnet Mask(default for most networks is 255.255.255.0) and Default Gateway in the boxes, and press OK.
  9. Now, run a test for Xbox Live. More than likely, you will end up failing the DNS check. This is alright, because we will take care of this in the next step.
  10. Go back to Network Settings, and then change your DNS settings to Manual. For primary DNS server, enter your default gateway.
  11. Run another Xbox Live test, and you should pass everything. However, your NAT will probably still be Strict or Moderate. If it is open, then you are done!
  12. Go back to your computer, and open up your browser. Type your default gateway into the address bar, and press enter. A username/password box should come up. This site has a pretty complete list of routers and passwords.
  13. Once in, look for a link titles “Applications and Gaming” or something along the lines of that. Click it, and then find DMZ. Click it.
  14. Click the “Enable” radio button, and type in the last(4th) octet of your IP(octet1.octet2.octet3.octet4) Save your settings, and exit.
  15. Go back to your 360 dashboard, and run another Xbox Live test. If all went well, you should now have an open NAT! Give yourself a pat on the back, and dance around the room a couple times
Posted on Jan 16, 2009
Change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
Jun 01, 2009 | Zyxel P660HW-D1 Router
Change NAT to open
First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
Mar 13, 2009 | Dynex DX-E401 Router
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
Change NAT to open
Go to portforward.com and then set your xbox to conenct using the DMZ option on your router.
Jan 20, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Change NAT to open
You need to call xbox live tech support. From there they will give you a code. This code will need to be entered in the settings for you wireless interenet product under "Port range forwarding."
Dec 28, 2008 | Arris SURFboard SBG900 Wireless Router...
Change NAT to open
Look through the menu's on the router for UPNP. Turn it on. Then turn it on on the XBOX. UPNP is Universal Plugand play. that should configure the router for you automatically.
Dec 05, 2008 | Zyxel P660HW-D1 Router
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Change NAT to open
Here you go sir, follow the instructions in the link below and your Xbox live will report an OPEN NAT and it will fix your connection problems.
http://www.portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/Xbox_Live_360.htm
Hope this helps!
Feb 09, 2008 | Belkin (F5D7230-4) Router (587009)
NetGear WGT624 Wireless Router Logo
311 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
