Question about HP LaserJet 4700 Printer
How do I fix an error 68.1 Permanent storage Full on the HP 4700N?
5 Suggested Answers
  • 489 Answers
SOURCE: `permanent storage full error` what does it mean????
The internal storage system is full. You need to run the HP Web Jetadmin software and delete unnecessary files from the EIO disk device. When done, press the select button on the printer to return it to a ready state. You should be able to print small jobs yet as long as it doesn't require any temporary (or permanent) storage on the EIO disk.
Posted on May 27, 2009
electronacs
  • 19 Answers
SOURCE: Permanent Storage Write fail
It appears that there is a problem with either the internal hardrive if you have this option installed, or the removeable Jet direct card if you have one installed, thirdly, it could be bad memory or the main board.
Go to HP's website and perform a firmware upgrade for your model if there is one.
I would first remove any add on option like networkcard, memory .... then turn the machine back on and see if the error goes away. You can also go through the menu and perform a fatory reset, this however in the process loose your IP address.
Onece you have aliminated the options I would move onto the main board or FIRMWARE
Posted on Jul 07, 2009
shishirgarde
  • 114 Answers
SOURCE: HP Color LaserJet CP3525 68.X PERMANENT STORAGE
Perhaps this link may help you !
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=de&cc=de&taskId=125&prodSeriesId=74301&prodTypeId=18972&prodSeriesId=74301&objectID=bpl11648
Posted on Nov 01, 2009
  • 6 Answers
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Posted on Jul 20, 2010
Hp lj2420 errcode 68.2
The printer permanent storage is
full. Some settings might have
been reset to the factory defaults.
1. Press the SELECT ( ) button
to continue.
2. For 68 errors, turn the
printer off, and then turn the
printer on again.
3. If a 68 error persists,
initialize NVRAM. See the
caution and note in To
initialize NVRAM.
4. If this error message persists,
replace the formatter (see
Formatter).
Apr 04, 2011 | HP LaserJet 2420 Printer
HP Laser Jet 5500 DN Error 68.8 permanent storage error Clears after restart of the printer.
68.8 is a new one. It's not in the manual. The only two 68 errors I could find are 68.0 and 68.1.
In any case the 68 error says that one or more of the printer settings got hosed and reverted to its factory default.
Go through the printer settings and see if you can find what changed.
The easiest way to check is to print out a menu map.
1. press the check mark on the control panel
2. press the down arrow to highlight MENUS
3. press check mark to select MENUS
4. press down arrow to highlight PRINT MENU MAP
5. press check mark to select PRINT MENU MAP
Mar 10, 2011 | Office Equipment & Supplies
I have one printer lj 2420 68.0 permanant storage full error
Error 68 is simm memory problem.
68 Error / Service / Cold Reset
All printers
  1. Temporary error. Cycle power to printer
  2. Bad formatter PCB
LJ4, 4+, 4P
  1. NVRAM not initialized.
68 Memory
IIISi, 4Si, 4V
  1. Bad SIMM memory. Check and replace SIMM's
Feb 05, 2011 | HP LaserJet 2420n Printer
Printer hp laserjet 2420 error 41.2 dan error 68.2
The 41.2 printer error means beam detect misprint error. To resolve this try the ff:
  1. Press c00099410.jpg (Select). The page containing the error automatically reprints if jam recovery is enabled.
  2. Turn the printer power off, and then turn on the printer power.
  3. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 ,
The error 68 regardless what number follows after it is about Storage Error. One or more printer settings saved to storage device x are invalid and have been reset to factor defaults. To resolve this:
Press c00099410.jpg (Select) to clear the error and continue printing. Printing can continue, but unexpected behavior might be experienced because an error occurred in permanent storage.
Hope this helps.
Thank you for using FixYa.
Nov 26, 2010 | HP LaserJet 2420 Printer
HP Laser Jet 4700n-Light printing on right side of paper. Removed all cartridges and toner, cleaned and recalibrated after start up. Still light printing on right side. Any suggestions??
Is the light printing the same for black and white vs color? Light printing on a side is not uncommon for these printers. It is usually caused by the laser optics getting dirty. But this usually shows up more in one color than the other. Such as something printed in yellow is fine while red is faded on one side. If the light on the right side printing is the same on all colors including black then I would suspect something with your transfer unit.
If you do notice that it us just on black or another color then it is definately time to get the laser optics cleaned.
Dec 18, 2009 | HP LaserJet 4700N Printer
HP Color LaserJet CP3525 68.X PERMANENT STORAGE WRITE FAIL
Nov 01, 2009 | HP Color LaserJet CP3525x CC471AABA...
Error 68.2 permanent storage write fail (Hp laserjet P4014n)68.2 permanent storage write fail. (for help press ?, to continue press ok) if i press ok it will print what ever job was sent but you have...
Hi! I will be glad to assist you in this issue.
Usually all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem.
here is the lin for additional solution:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
Oct 26, 2009 | HP LaserJet P4014n Printer
My hp laserjet P4014n is giving an error message 68.2 permanent storage write fail what can i do to clear this massage?
Here is the link just incase you need more solution:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
May 27, 2009 | HP LaserJet 4250n Printer
HP LaserJet 4700 Printer Logo
1,866 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
