Question about Belling 27 in. CTC465 Electric Cooktop
Touchtronic My touchtronic hob will no longer work when touched by my fingers. I now have to use a kitchen towel to activate it can any one tell me why
  • peter madeley Dec 02, 2007
What does F flashing mean on miele nduction hob
F means foreign object. In my case a dish towel covered about 10% of the touch panel, so it is really sensitive. In your case just see if anything is on top, or it may be that your stove is tricked into believing the front panel can't be used because something is covering it.
Dec 22, 2012 | Cooktops
Hob light up.
I take it the two fuses you mention were the house fusebox and the fuse in the outlet in your kitchen? If you know the mains is getting to the hob and nothing at all is lighting up on the panel then this sounds like a job for the professionals. I can't find any mention of a reset button or user acessable fuse in the manual. The only thing left to do is check the main wire connection underneath the hob - if it is accessable. (switch off at the wall first!) Assuming you are in the UK Service force telephone number is 08705 929 929 Hope this helps.
Sep 29, 2007 | AEG 23 in. 67600KF-N Electric Cooktop
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 | Cooktops
We have a neff induction hob which for some reason has no instructions and my little brother managed to lock it (so that a key symbol lights up above the on switch and all functions are disabled, i need to...
Try - set all hotplates to setting 2. Switch off jot plates one after another starting with front right in clockwise direction, touch main switch for at least 5 seconds & a signal will sound - this activates & de-activates the child lock - or so the instructions say...
To use the hob with the child lock on - it says to press the main switch for more than 4 seconds & that lets you use it.
Jun 15, 2009 | Cooktops
Fagor hob touch control
Our hob has the same problem. I would really like to know the reason for this! Try using a rubber eraser instead of your finger - this works every time with our hob. Covering Up and Down arrows with the rubber, zeros it instantly just like using both fingers. Hope this helps.
Jan 28, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
Two elements not working
First of all, are you sure it is the elements and not the controler? To test the elements, lift theplate out of the worktop, change the 2 wires from a good element to that element. put the plate back in it is home and use the good elements touchtronic button to turn on the element. I am willing to wager that it is the control unit and not the elements.
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
PROBLEM WITH HOTPLATES SWICTHING OFF
Sometimes this happens if the pan bottom is not completly flat or is highly polished. Darker, flat pans work best. It sounds as if the safety is cutting off the burner.
May 31, 2008 | Cooktops
Neff Hob
Hold the power button for a few seconds
Feb 16, 2008 | Neff 23 in. T1443 Electric Cooktop
Neff 4 ring, ceremic top hob - how do I turn on!!
You press the "on" which is on the left. Press the picture of hob you require and press the up and down for temperature. Then put your pan on the hob and it will work. If you need to adjust the temp you need to remove the pan.
Oct 15, 2007 | Neff 23 in. T1443 Electric Cooktop
Belling 27 in. CTC465 Electric Cooktop Logo
291 people viewed this question
Top Belling Cooktops Experts
ray gallant
Bill Boyd
Are you a Belling Cooktop Expert? Answer questions, earn points and help others
