I bought a Treo 650 with your bluetooth Logitech HS04 V01. I cannot work out how it connects and I didn't get a manual. I have tried to setup the hands free option but the Treo wont recognise the Logitech HS04 V01. I have fully charged the unit but it is not found in nearby devices, What am I doing wrong? Mark
Try turning off the headset. Then setting your phone to look for bluetooth device. Touch and hold for ten seconds the larger button on the headset, should flash blue light rapidly. then command phone to find device, (commands differ from one phone to another). When phone "finds" headset blue light should change to intermediate flashing (three flashes every five seconds aprox.) Hope this helps..
Push and hold the longest button while you're searching for the device. access code should be 0000
Who has logitech HS04 V01 operating manual?
I would like to have passcode to establish a secue connection with Logitech HS04 V01
Suggestion 5 is the Answer to my mind numbing, time wasting problem of pairing the HS04 with my E71
THANKS A MILLION!
Thanks Fellas. I made it work mine. 0000 is the answer
The code is 0000. I paired mine with my treo 680 and laptop up to last evening. Sometimes there's a difficulty with detection. Once you turn it off and turn it back on it would generally be detected by the other device.
I believe the default key is 0000. I've had the Logitech HS04 V01 for a couple of years, but haven't really used it much in a while. I also just got a Treo 650 from work, and had trouble pairing them as well, as I forgot the code and didn't want to bother digging up the manual, lol. Don't remember where I found the info, though, but try that. Good luck!
0000
I need the key connection thanks logitech hs04 vo1
Did u chnage the mode in detectable, with my hs04 v03 i have to press the multifunctionalbutton for ten minutes
trouve pas son pilote sur vista
I lost the instruction book and now I can not set it up because I do not have the code thanks
i have a nokia E62 that finds my Logitech HS04 V01 but asks for a passcode each time which I don't have (no manuals) please help!
LOST INSTRUCTIONS NEED THE CODE
i have a razar and the device is on and the phone is unable to connect
Lost instruction need the code
