Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP invent picture is on but "ON" switch doesn't work
Printer obviously has power. Power connections are good, It's wireless, no cables, just a phone and phone connection for faxes. Unplugging and plugging the power module, switching the wireless box on and off changed nothing. Power module is probably good since it has power. I suspect the printer is bad. Uninstalling and reinstalling the printer software didn't do anything - couldn't find the printer.
    Scholar:
  • 86 Answers
So is there any way you would be able to plug it up and see if it can connect over cat5 or USB? It is possible the drivers are installed wrong and need to be reinstalled or it could be something to do with your network setup. See if the printer is installed in Printers in Control Panel and if so check the network settings of the printer setup and verify that it will work with your home network, IE on the same subnet.
Posted on Jan 01, 2009
  • Sudo Bash Jan 01, 2009
    Probably a wireless problem if the printer is powering on.
  • 177 Answers
Hello and welcome to FixYa!,
It sounds like the Printer is Defective, You may need to Replace It!
Hope this helps -- P3NGYJO3
  • HP Master
  • 6,487 Answers
Yes, there's a big chance that this printer is already bad since you have problem with the power of it and you already done the necessary troubleshooting if this printer is still under warranty better have it replace...
My Hp 6500 wireless won't do anything. The keypad on it won't even work. Any thoughts?
You don't say what trouble shooting you've done. So lets start with the basics: 1) make sure your power cable is plugged all the way in from the back of the printer to the power strip. Make sure your power strip is on. (cannot tell you how many times this has been my problem). Make sure the plugs on both sides of the transformer (the black box in the power cable) are plugged all the way in. I'd unplug and replug everything.
2) The power button on this machine is not real obvious. It is to the left and aligned with the top of the control panel screen. I've attached a picture.
3) if that doesn't do anything open the cartridge access panel. The machine should light up, give you an error message on the control panel.
4) if none of these work and you've rechecked your power, I'd take it back to where you purchased it.
Aug 22, 2014 | HP Officejet 6500A Plus Wireless...
HP invent screen with scrolling bar continues forever and printer never powers up beyond this.
Please try disconnecting the power cable for a few minutes. Then, reconnect the power cable and try turning it on.
Mar 02, 2011 | HP PSC 2355 All-In-One InkJet Printer
After a simple paper jam that was successfully cleared the Power On light on my HP 7410 went off and the LED screen displays HP Invent with the status bar continuously moving left to right. All of the...
if you haven't tried this already...pull the power cable out or switch off at power point for few seconds. Then plug it back in and power up...
good luck
LC1000
www.inkbank.com.au
Dec 08, 2010 | Office Equipment & Supplies
Hp7410 Wont turn on and function, power light doesnt come on and the HP Invent Logo keeps cycling on and off
you might want to check to see if the wireless for this machine is connected to main pcb, if so, disconnect, you will have to pull off the back of the machine, requires #10 torq bit, cable is a 4 wire cable, it travles from right of machine to left of machine, the only other cables that travel from right to left, is speaker cable, only 2 wire, and then the doc feed cable, which has 8 to 10 wires on it. if problem still continues, then main pcb will need to be replaced.
Sep 23, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Hi. I have a HP all in one printer (C6100). It keeps turning off then immediately back on. Can the printer be reset?
The below are the resetting steps for this printer model. Try next reset if the first one did not help. Do not try all resets together
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech.
Aug 18, 2010 | HP Photosmart C6100 All-In-One Printer
Display screen stuck on hp invent - buttons don't work
This is apparently a common problem with this model, but HP has not offered any help with it. Mine did it a few weeks ago and I found the solution in another thread on fixya. Follow this link and then open the back of the printer and disconnect the wireless card as described by Maggix. It will kill your wireless capability but let the printer start working again.
http://www.fixya.com/support/t648531-hp_7410_all_in_one
Jan 01, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 6210 printer
unplug all the cables ang plug them back in
also try reseating the cartridges
May 28, 2008 | HP OfficeJet 6210 All-In-One InkJet...
No Power to printer?
may be your adoptor is faulty check your power cable and the paoer switch button .
Sep 28, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
18 people viewed this question
Ben Johnson
