Question about Microsoft Xbox 360 Console
Still trying to solve xbox
Tried all your suggestions but nothing. Someone else said they believe it is the machine itself, is that a possibility or do you think it could be the cables? If you could let me know asap please that would be awesome.Thanks so much for your help.
  • 44 Answers
How old is your machine?
Posted on Jan 02, 2009
  • lil_fatty_8
    lil_fatty_8 Jan 03, 2009
    That didn't work... Hmmmm. actually i've been hearing alot about this lately... im 90 percent sure that it's not the cables...... but just in case... make sure that the setting on the av cables is correct there is regular tv and HDTV..... disconnect everything and reconnect it.. I think this is a problem with the GPU... in the event of this happening.... sometimes taking a heat gun over the gpu for about 10 minutes or wrapping a towel around it for 10 minutes will work... Sometime! , not always! .... with these kinds of troubles, i know a person is almost better off buying a new one,. especially since the prices went down on them. (360 arcade - $199) .... try these things and if they don't help, let me know.... i will try to figure out the answer also...
TV Turned Itself Off - Now - No Power No Lights Flashing
power supply board is faulty need to check the power transistors and fuses u will need a tech to solve this
Jul 14, 2013 | Samsung HL-R6167W 61" HDTV
I cant sign in to xbox live even though when I test connection it says the console is connected to xbox live
It might be a problem with your router, if you turn it off for 30 seconds like it suggests, then it should work. If not you might want to try to recover your account. This happened to me the other day, I waited 30 minutes and tried again and it solved itself.
Oct 03, 2011 | Microsoft Xbox 360 Console
How do I fix a fuzzy screen
A fuzzy television screen is generally not the fault of the game console itself, but of your television.
The Xbox 360 is an HD game console, and from personal experience, trying to render an hd image in 480i Standard Definition will cause it to look somewhat fuzzy regardless of the television.
Just to make sure it is not the Xbox, I would, if possible, suggest you try the 360 on another television, preferrably with the HD cables (remember that there's a switch on the cable itself that you will need to switch from SD to HD).
Unfortunately, if you do not have access to a high def television, you can always fiddle with the contrast and sharpness on your standard def TV to reduce the fuzzyness, but the screen will always be somewhat fuzzy.
I realize this is probably not the answer you wanted, but to solve this problem for my own Xbox, I ended up purchasing an inexpensive HD Television.
Nov 01, 2010 | Microsoft Xbox 360 Console
My xbox 360 controllers will NOT sync , i tried looking online and i tried every posible way. But nothing worked , is it the controller or the xbox itself. it worked purfect lasst night and it fell on the...
I'm sure you have tried most of these steps but I'm going to list them any way. So we have a complete picture of the trouble shooting process.
1. Sync system first (By pressing the sync button on the system)
2. Right after you hit the sync button on the system, hit the button on the controller
Try replacing the battery's and or rechargeable battery for the controller. Repeat the sync process above.
Try another controller with your xbox or try your controller with a different xbox. Repeat sync process above of course.
If another controller works with your system than that would indicate that there is an issues with your xbox controller.
If your controller works with another xbox and no other controllers work with your xbox than there is a issue with your console.
For issues related to the xbox I would suggest contact xbox directly by calling 1800 my xbox.
If possible please rate the solution I have posted.
Aug 25, 2010 | Microsoft Xbox 360 Controller
My xbox wont work
The Xbox 360 will break from over heating itself. Maybe the rattling was the cooling system. Send the Xbox 360 to Microsoft and they will send you a new one free.(Save your hard drive!)
Jul 15, 2009 | Microsoft Xbox 360 Console
Game wont play even after cleaned
Hi, This has happened to my before.  I believe you are talking about when you move the XBOX while the disk is spinning and a spiral ring is scratched into the disc.  The only thing you can do to fix this is to buy another copy of the disc, or if you have the latest updates on the console (which is only possible if you use XBOX LIVE), you can rent a copy of the game and install it on the Hard Drive.  If you do install the game, don't throw away your old game, because you will still need to put it in the disc drive.  Hope this helps! :)
Apr 19, 2009 | Microsoft Xbox 360 Console
Disk reading error
this is a possible laser read problem.
Try an official DVD Movie. And also a music CD.
if it reads nothing at all, i,d suggest a laser head cleaner.
Or a replacement DVD Drive.
Mike @ compurepair.
Mar 26, 2009 | Microsoft Xbox 360 Console
360 says unplayable disk
YOU PROBABLY HAVE A BAD DISC DRIVE OR THERE IS A SHORT POWERING THE DISC DRIVE
Jan 28, 2009 | Microsoft Xbox 360 Console
Headset icon on 6085
I trawled the net looking for answers. Some suggestions were, take out battery and sim for a few minutes, restore factory settings, clean connections... someone even suggested you put it on the washing machine while it was in use! I tried all of the above without success (yes, even the washing machine one). I rang the Nokia helpline and all they offered was the suggestions above and to send it in to be fixed. I was answering the phone with the headset in, just by chance, after a day or so I removed the headset and voila! problem had solved itself, icon was removed. It did come back when someone made me a call but I put the headset in for a few minutes then took it out and the icon went away. Hope this helps :)
May 20, 2008 | Nokia Consumer Headset
Copies with the Brother Fax-T104
I presume that it is possible to send a fax normally? To make a copy, the machine is basically sending a fax to itself. Therefore if it is possible to send a normal fax and setting the paper to make a copy in the same way as faxing doesn't allow the copy button to work, then the fault is in the machine. Believe me this machine isn't worth spending money on.
Dec 21, 2007 | Brother FAX T104 Plain Paper Thermal...
Microsoft Xbox 360 Console Logo
14 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
