Question about Roper REX3614KW Electric Dryer
Warm heat..clothes not drying
Hi..I have a roper by whirlpool/heavy duty/exlcap/3cyc model number rex3514rq1...the dryer works but heating temp is very low..will I need to replace the element? If so, could you provide the repair manual and the element part number..Thanks ..John
    Sergeant:
  • 311 Answers
John there is only one heating element.ither it works or it dosent.when acustomer complains of low heat or long dry times 99out of100 its the venting or the dryer is blocked with lint.remove the dryer from the venting and try a load.if better clean house venting.you .........if not better you should have a great air flow leaving the dryer so if not drying well with venting off.take dryer apart a clean all araes that air is moving,where lint can block that flow.god bless .tom
Posted on Jan 01, 2009
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly stopped..no sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
Model REX3514RQ1 series MT1328736 NOT HEATING
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 27, 2011 | Roper Dryers
It takes at least 2 cycles to dry clothes. It is Roper heavy duty high capacity electric dryer. Thank you for any help you can give me. janebellard@yahoo.com
Check for air restrictions which cause the heat control to shut down faster than normal.
When the moisture cannot be removed fast enough the heat builds up and has nowhere to go so the heat control stays off longer and the clothes just tumble on.
Service manual and more HERE
Mar 14, 2011 | Roper Dryers
Whirlpool Electric Heavy Duty Dryer. Model number LEV7646AWO or 0. Takes teo cycles to dry the cloths. Lint screen is clean. No obstructions in venting to the outside.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Dryers
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
Whirlpool model number LGV7646ANO gas dyer will not heat up
Can you hear a click like always? If not then it has to be either the fuse, ignitor,or sensor. If you hear it clicking then the operator coils are dead. HERE is a link that shows pictures of these parts and locations.
Jan 19, 2009 | Whirlpool GGQ8831L Gas Dryer
Warm air but clothes not drying
Make sure u have seleced the high heat setting..The fact that it is heating more or less indicates that the element is o/k.
Check and clean any filter(s) that u can see,it is more likely to be a thermostat problem than anything else. and there are at least 2 of them, also check line voltage is correct.
Plz rate this solution.
thanks.
Jan 01, 2009 | Roper REX3614KW Electric Dryer
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Oct 08, 2007 | Kenmore 63942 Dryer
Roper REX3614KW Electric Dryer Logo
349 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Roper Dryer Expert? Answer questions, earn points and help others
