The Ai3010 - fading image at 200,000 copies = needs a new Optical Drum + Cleaning Blade + Main Charger Wire + Developer + Transfer Assembly.
Hi Joe in Tampa, What part of Tampa are you in? I use to live in Tampa. Are you asking about a Di-3010 or ai. If it is a Di you can most likely just clean the primary charge unit that charges the drum. I would clean & check the primary grid. If you clean it you have to remove the grid from the unit ( it has a push botton to release the tension of the grid) I would use Windex to clean it. The try to reinstall the drum unit and see how it works. It may be that the drum is worn out, but I don't know how many copies are on it. If it is a smaller desk top version you may need to change the drum cartridge. I'm not to sure what a ai-3010 is. Good Luck
