Question about LG LSC26905TT Side by Side Refrigerator
LG LSC 26905TT Panel Not Working / Frozen ice on back panel fzr
Multiple problems. Started with ice on back panel of freezer. Panel on front quit working with only two lights on the panel. Temperature in the fridge and freezer is going up.
  • Anonymous Jan 21, 2009
    Same problem, panel not working, frozen ice on back panel, Need some help here......
5 Suggested Answers
  • 31 Answers
SOURCE: Display stops working
new control.
and LG parts are only available through LG at this time
Posted on Oct 07, 2009
Testimonial: "Thanks. I was afraid it would be one of those high $$ solutions (sounds like $200-$300). Thanks for the insight."
omaharox
  • 166 Answers
SOURCE: LG LSC 26905SW control panel for temp, ice,
Replace the control pnl.
There is no way to fix the existing control.
Posted on Jan 17, 2010
  • 26 Answers
SOURCE: Ice maker on an LG American Fridge Freezer doesnt work- why?
it can't freeze
Posted on Jun 12, 2010
martineznoe8
  • 92 Answers
SOURCE: My LG LSC 26905TT Refrigerator
HI.IF THE REFRIGERATO BOX OR DIVIDER IS HOT ,CHECK THE CONDENSER MOTOR ,FOR RESISTANCE OR CONTINUITY,CHECK FOR POWER COMMING TO CONDENC MOTOR,, IS OK REPLACE THE CONTROL BOARD OR REPLACE BOTH..GOOD LUCK..
Posted on Jul 04, 2011
My LG LSC 26905TT Refrigerator started to heat up around the outside of the freezer side/top and center bar between the fridge and freezer. The freezer is not freezing no matter how high we set it or the...
Jul 04, 2011 | LG LSC26905TT Side by Side Refrigerator
ICE MAKER NOT WORKING LBC22518WW (LG REFRIGERATION)
Hello, just like your problem, our ice maker just stopped making ice. We solved the problem by unplugging the refrigerator for about 2 hours leaving the freezer door open.
It started making ice a few minutes after plugging it back in. Obviously the line that supplies the water had frozen and this allowed it to un-freeze.
We didn't remove any of the frozen items in the freezer, at the two hour mark, everything in the freezer was still mostly frozen.
Thanks
Jul 13, 2010 | LG LBC22518 Bottom Freezer Refrigerator
Jan 12, 2010 | LG Refrigerators
I have a lg lfx25960sb,it is showing ER IF code on the panel above ice /water door,also not making ice?
ER IF indicates that the ice maker fan is not working. The fan is probably frozen. Remove the fan duct and housing at the back of the freezer and you may be able to defrost the ice in the fan enclosure. It will not defrost sufficiently by turning the freezer off for 2 to 4 hours as LG suggests. The fan may have frozen because of high humidity or because the defrost cycle is not working. If your unit is still under warranty LG should fix it by replacing the fan, duct panel and control board with new ones that have been re-engineered to prevent this problem.
Dec 16, 2009 | LG LFX25960 Bottom Freezer French Door...
Ice cube maker not working. digital display not
The ice fan is frozen. It is located behind the rear panel inside the freezer2.gif drawer. I had the same problem with an LG refrigerator in November 2008 that was fixed under warranty. (There is a Kenmore model that is made by LG.) They replaced the fan and housing, and the panel duct assembly (both because a design revision provided a way to drain the water that was freezing the fan), and the main controller board (presumably because there was a new defrost program, but also because of the Energy Star settlement.) If your refrigerator is out of warranty, you can remove the freezer drawer to get at the panel behind it. Remove and defrost the fan housing. Drill some small holes in the bottom of the fan housing for drainage. Put it back together and see if that solves the problem.
Oct 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
new control.
Oct 07, 2009 | LG LSC26905TT Side by Side Refrigerator
Where is the water filter located on my LG LSC 26905TT refrigerator?
Open the left door, look up to left top, there should be and s looking cap.
Jul 14, 2009 | LG LSC26905TT Side by Side Refrigerator
Lg frost free fridge freezer gr-399sq
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
Jan 05, 2009 | LG LFD22860 Stainless Steel Bottom Freezer...
LG LSC26905TT Side by Side Refrigerator Logo
90 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
