Question about Whirlpool Inglis IP4400 Washer
Parts diagrams or base schematic
I had to take apart the washer to replace the pump.
I now need to figure out how to replace pins and floating base plate.
  • Whirlpool Master
  • 8,220 Answers
The pins are for shipping so no need to put them back. The rest just bolts on. You should have removed the case to get to the pump:
READ THIS
Posted on Feb 20, 2009
Fridgidaire GLET1041AS1 need assembly/dissasembly schematic so i can take it apart
Good Morning lzook, thank you for your post!
I understand you are seeking a Parts Manual and Wiring Diagram for your Frigidaire washer, GLET1041AS1. I have located information about your washer on the manufacturer website. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Dec 12, 2013 | Frigidaire GLTF1670A Front Load Washer
Schematic for a Briggs & Stratton fuel pump & carbrater
most of the time you will not need new parts but the only parts out of the kit you will need is the needle valve (the part on the float) and the bowl gasket the first thing you do is take off the bowl then there is a pin that holds the float down pull it out with a pair of pliers i like one sided wire plyers then drop the carb and bowl in carb acid for 45 min i use chem dip u can get the gallon can for 25 bucks at autozone or advanced auto after 45 minutes pull out the carb and blow off wih air chuck from an air compressor blow out all the littlle holes they are inside and out reinstall float and needle valve reinstall bowl turn air fuel mixture screw all the way in till snug do not over tighten or youll damage it turn back out counter clock wise 2 turns reinstall carb thank me
May 14, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Rci-2950dx 4 pin microphone wiring schematics
you can't because of the up/down buttons on the mic. the 2950 is a 6 pin and the d-104 is a 4 pin. If you can figure a way to eliminate the u/d switch then go for it. there is a wiring diagram on www.cbtricks.com
Jan 15, 2012 | Midland 1001Z 40-Channels Base CB Radio
My machine was vibrating during spin. so I took
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The section on the Base should have a diagram of where the springs and vibration pads attach.
Ths following Whirlpool Service Manual for top load direct drive washers also has a section on the base and where the springs attach.
Nov 15, 2009 | Kenmore 24032\24036 Top Load Washer
I need instructions for replacing snubber pads
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Look at the diagram of the machine base.
If you have the basic Kenmore top load, you can use a thick screwdriver to pry the tub base up from the machine base and pop the old pads out.
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
I had a mouse get into the under part of the dishwasher. He/she/it got trapped and died. The smell made us aware of the problem. I had to take apart the bottom of the dishwasher and take out all the...
There are no diagrams available of this - however using some logic - you can figure out the path of the water.
A picture of the bottom of the washer would be helpful as well.
Water comes in from the water inlet hose to the pump. Then from the pump - it goes out to the impellers (water wands).
Then the drain (chopper) inside the washer goes to a solenoid operated valve that discharges into the garbage disposal or waste drain.
Thanks
Aug 09, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Washer won't drain.
Remove power first! The pump is very easy to remove, ( unlocks from the base ) take the pump apart and check for foreign objects inside the pump assy. The power wires pull off and matters not which way they go back on. Also check the hoses to and from the drain pump for any foreign objects. The pump is usually at the back right side ( looking at the washer from the front )
Apr 01, 2009 | Washing Machines
BOSCH DISHWASHER Flooding
Removing the water level sensor it is not a difficult operation, it is held with one bolt at the base of the floater arm.
The problem is that you cannot be sure that the floater is not working unless you find out that the floater is filled with water or stuck.
There is an electronic test to verify if water level switch activated by the floating sensor is working. Instructions here: Bosch dishwasher helps.
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Feb 07, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Whirlpool Inglis IP4400 Washer Logo
193 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
