Question about HP OPTICAL SCROLL MOUSE (8131)
Hp mouse problem
My screen now does a slow fade in and fade out when I click on an item. It is like slow motion.
  • oshadowcat Jun 28, 2008
    I was using a cordless HP mouse and then went back to using the HP optical scroll mouse. I cannot get the scroll mouse to work at all. How do I fix this problem?
Hi my new hp bluetooth laser mouse does not work. It will work, then when you switch users, or turn off the computer and then turn it back on, it stops working and will not work after that.
Posted on Jan 10, 2008
Why is the picture on my Sony KDL-55HX729 blurry? The right side of the screen is light and blurry like its in slow motion and retains the previous screen picture, it fades after a few secondboard may
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 19, 2014 | Televison & Video
Tip
How to Increasing Graphics Performance
By default, WindowsXP turns on a lot of shadows, fades, slides etc to menu items.
Most simply slow down their display.
To turn these off selectively:
  1. Right click on the My Computer icon
  2. Select Properties
  3. Click on the Advanced tab
  4. Under Performance, click on the Settings button
  5. To turn them all of, select Adjust for best performance
  6. My preference is to leave them all off except for Show shadows under mouse pointer and Show window contents while dragging
on Sep 20, 2010 | Computers & Internet
Sanyo dp42849 picture is slow
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 22, 2017 | Sanyo DP42849 42 in. HDTV
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.
Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.
Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."
Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.
Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.
Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
I bought a mouse (HP Wireless Optical Mobile Mouse (VK479AA)) and I can't hold down the keys. By that I mean when I hold the button down, it isn't held, instead, the computer thinks I'm constantly pressing...
I have the same problem. I posted on HP forum but did not get any help. I contacted HP technical support. They sent me a new mouse but it behaves the same way.
Aug 13, 2010 | HP Wireless Optical Mouse
I can't hold the left button down and drag pictures or icons on the desktop.
Check if the mouse has been aligned for to be used by Left-Handed or RIght Handed people. If the settings are correct try reinstalling the drivers for the mouse. If that doesnt help either, try replacin the mouse and see if that helps.
Apr 07, 2010 | HP Wireless Optical Mouse
Mouse moves too fast
You can always control mouse pointer motion (speed), by using Mouse Option in Control Pannel. Open Mouse option in control pannel. Here you can go to Pointor Motion, now move the slider to left side. Click on Apply and check mouse speed. When you get the required speed, Click OK.
Thanks
Mar 21, 2010 | Logitech V450 Laser Cordless Notebook...
My cordless optical mouse is slow dragging across the screen. When first used it is fine but then slows down. Ideas anyone?
Try this...
Go to Control Panel > Mouse > Pointer Option
There you can increase the pointer speed/motion.
I hope this helps. If not please inform me. I will see what else I could do.
Jan 30, 2010 | Logitech 9313960403 Mouse
Quickplay on laptop plays everything slow motion and no sound, no sound for games most of time.
Are you running xp or Vista?
In XP go to device manager and expand list of IDE ATA ATAPI controllers. Right click on primary IDE controller and select properties. In advanced screen check primary IDE mode - that should be DMA.
IF that is in PIO mode - that is your problem.
Just click on driver tab in the same window and click uninstall.
REstart computer twice and problem should be solved.
Please leave your feedback if issue is solved
May 28, 2009 | Computers & Internet
HP OPTICAL SCROLL MOUSE (8131) Logo
817 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
