Question about Home
American standard air tub motor hums
The motor has a hum but nothing comes out of the jets it has only been used 3 or 4 times we are remodleing the bathroom unpluged it and it was working now we pluged it back in and now the motor just hums need help thank you
  • 2 more comments
  • lorddrago3 Jan 03, 2009
    my whirlpool hum as well, dont use it that often, thought i was preserving it, but i guess if u dont use it u lose it..
  • tdavis256 Jan 03, 2009
    My American Standard does the same hum. Only used about 3 times and owned for less than 6 months. Motor hums, but jets don't turn on.
  • notime2rest Jan 07, 2009
    I have the same problem, I haven't used the jet tub in quite a while. The tub is in our master bath and is on the second floor. The access panel is outside on the second floor. Do I call a plumber for this? I can hear it hum, but nothing comes out of the jets. Please help.
  • sheephunter Jan 08, 2009
    I have the same problem, motor hums but no water movement
That motor solution is correct. I called the company American Standard and fortunetly, mine was still under warranty. They sent out a plumber within 3 days to replace the motor and now I'm back in Kansas Dorothy.
Posted on Feb 24, 2009
  • 125 Answers
Sounds like the motor might be on a dead spot. try turning the shaft of the motor 1/2 turn or so and see if it will kick in. If not you may have a bad motor of some debris in the motor preventing it from starting.
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
When I push the button to start the jets, it just hums but no water comes out of the jets
there may be something caught in the impeller in the jet motor. remove it and clean it out.
Dec 03, 2010 | American Standard Home
Not bubbling
i am assuming this is a jacuzzi make sure the air ports are not clogged it has to **** air to be able to make bubbles
May 09, 2010 | American Standard 2770.018w.020 Cadet...
Jetted bath tub has stopped working. Motor hums
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
Feb 15, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
American standard jacuzzi tub will not work. motor hums but jets do not come on
is this a new install? if so you may need to adjust the air intake. Or if you have kids they may have messed with the settings. If the air is closed all the way off....no bubbles.
Oct 18, 2009 | American Standard Antiquity 2038.016.020...
My American Standard whirlpool pump will only hum.
The bearings (or bushings) of the pump or pump motor have siezed, these can be replaced on some models but for the most part you will need to replace the pump and/or pump motor. and as where to get parts, i would suggest the outlet from wich you purchased the unit or another appliance outlet. Or if you feel up to the challenge, im sure you could find replacement parts on the internet: google, ebay, etc.
Sep 29, 2009 | American Standard 2770.018w.020 Cadet...
I have an american standard air tub and cannot get the air jets to shut off.  They turn off, but come back on automatically a short time later.  How do I shut the power off?
Check the air vacuum switch and line as you may have a air vacuum leak. The button that controls the on and off to the jets is an air vacuum switch....It may have a slow air leak in the line or connections that is activating the on and off control
Dec 16, 2008 | American Standard 2748.328 Town Square 5'...
Home Logo
567 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
