Question about Acer Aspire 5100 Notebook
Usb problem need help with my acer aspire 5100 anything connected by usb is getting the message device malfunctioned anyone got a clue what to do please help im desperate
  • 2 more comments
  • ddbarnes Jan 01, 2009
    thanks but which one on here is the vista usb driver
  • ddbarnes Jan 06, 2009
    thanks nothing worked though its been back to the shop they said its a problem on the motherboard and it can only be fixed by replacing this at a cost of £400 this is rediculous as i only purchased the machine 18 months ago can anyone tell me another way of sending music to my ipod as i am not replacing a £500 laptop just so usb works
    it is an acer aspire 5100
  • ddbarnes Jan 07, 2009
    not got a clue about the bios but i sorted it by buying a usb that slots into pcime slot and that seems to work but there is another issue i had to install a second vista on my computer as the first one crashed when trying to factory restore the laptop and would not boot up so i used my mates dell vista basic disk it all works ok but my hard drive is looking abit full would you remove the original acer vista home premium and if so how do i do that
    Brigadier General:
  • 5,158 Answers
Start here and look over the drivers for your computer. download the usb driver and install it again. see if that helps
Posted on Jan 01, 2009
  • Roberta Smith
    Roberta Smith Jan 01, 2009
    confirm your model please
  • Roberta Smith
    Roberta Smith Jan 06, 2009
    there are some rumours going around the net that that motherboard has issues.. watch for recalls... i was looking over the drivers for it..i will try to get back to you on that. do you know what bios is running on that computer ?
My Acer Aspire 5100 tells me that my USB port are
Check the driver status of the USB. You can do this by accessing the Device Manager. For users using Windows XP, just click the Start icon. On the Run box, type devmgmt.msc. You can also do the same with Vista.
Next thing, check for devices with an (!) sign with a yellow background. These devices needs driver update or correct driver should be installed.
For a start, you can do a Windows Update. Click Start, All Programs, and then Windows Update. This will download patches for your system.
Oct 17, 2009 | Acer Aspire 5100 Notebook
Acer 5100
Is the keyboard on the laptop working? Also Does it recognize when you are plugging in the usb device? Go to your device manager and see if there are any exclamation points. Its possible a driver is corrupt or not installed.
Jul 11, 2009 | Acer Aspire 5100 Notebook
USB not working
If none of your USB ports work, there could be a problem with your USB controllers. Uninstall the USB controllers via Control Panel - System ... and reboot your laptop. They will reinstall upon bootup. Good luck.
Jun 13, 2009 | Acer Aspire 5100-5033 Notebook
USB ports wont recognize anything I plug in
Are you using XP? If so:
Here is what you can do to refresh the USB ports:
1. Right click MY COMPUTER
3. Select HARDWARE
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB device.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 02, 2009 | Acer Aspire 5100 Notebook
Usb malfuction
just because it says it doesn't recognise it doesn't mean it won't work. Plus if it's a device needing drivers you should download and install the drivers first then attach the usb cable. Go to the manufacturers website and find the drivers for the product downloading and installing the proper ones for the version of windows you have.
Also if you had listed what it was.... make and model could've given you a link to the drivers
Feb 18, 2009 | Acer Aspire 5100 Notebook
CD/DVD drive and external harddrives via USB not acessable
I once had a problem like this. It turn out that i just forgot to plug of my external drive. because of the lack of power of the device, it wasnt functioning properly. Try to see if you have two USB plugs, or one Usb plugs with a power cable.  Re check if both of the plugs are indeed connected properly.
Feb 01, 2009 | Acer Aspire 5100 Notebook
Acer notebook usb not recognized
Sounds like a hardware issue. I would guess that there is a bad connection between the usb's and the motherboard. If you are comfortable dismanteling the laptop and re-soldering the usb's than give that a try, but I would recomend you give it to a pro.
Here is a link that explains the process.
Jan 17, 2009 | Acer Aspire 5100 Notebook
all the drivers for the 5100 series are available here
My 3512wlmi also had a bluetooth button but when pressed I got the message, no device, if you get this message you don't have bluetooth but a upgrade is possible.
Jan 03, 2009 | Acer Aspire 5100 Notebook
Acer usb cam makfunctioning
try consulting the mfg for updated drivers. Try removing the usb port it's using and letting it redetect the port, also see if there is special software that comes with the usb camera and reinstall that. If all fails reinstall windows.
Nov 19, 2008 | Acer Aspire 5100 Notebook
Trying to restore my system
Just use original OS and repair OS
Dec 07, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
