Question about Yamaha RX-V490 Receiver
Can't get zone speaker to work on RX-V3800
Was working initially...tried all the setting and volume control...just can't seem to make the zone 2 or 3 speakers work on any source.
Anybody have a solution?
  • 151 Answers
SOURCE: Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Posted on Aug 05, 2008
SOURCE: Yamaha RX-V663 Multi-zone question.
i just got the same receiver like few days ago im still leaning it too,it is a very nice receiver though. here is some settings to help you.
check this to make sure zone 2 is showing in the menu,
on remote
menu,basic setup, speaker set,extra should show zone 2 it might show zone b...presence...or none needs set on zone 2 hit the left a-e/cat button it is weird the right doesnt circle all around? i had to call crutchfield tech for that one(GREAT COMPANY!)so that is for the setting to make sure zone 2 is set up now some to adjust the volume.
menu, manual,options,zone 2 set. here you can set 2 features
max volume( the loudest it will play) inti vol(the volume that it will play at when it is turned on) the yamaha has alot of quirks to it but has a very nice sound. for second zone features and a easier receiver to set up i have onkyo and they are very easy to set up zone 2 olume and everything on the front panel. hope you dont have to try to program a universal remote to work it seems yamaha uses discrete codes that are impossible to find i tried one universal and can only get very basic features to work.
hope this helps you out,
jeff
Posted on Aug 10, 2008
  • 142 Answers
SOURCE: multiple speakers on zone 2 0r 3 speaker output terminals
I wouldn't hook anything up except what Yamaha recommends to the speaker output terminals. That's pretty much asking for trouble!
barneyluc
Posted on Oct 10, 2008
SOURCE: Yamaha RX-V3800 receiver zone two audio problems
To get audio with this set up also hooked up analog audio RCA cables for the audio for each piece of equipment for 2 channel out put. Zone 2 will not out put a digital signal and this receiver will not down convert a audio signals to analog if using digital audio hook-ups.
Posted on May 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: Denon 1910 Zone 2 no sound
Typically, Zone 2 is for a different program than the one you're hearing in the main listening room. You can choose any source for Zone 2 EXCEPT a digital one.
Posted on Dec 29, 2009
I cant get zone 2 to work on my yamaha rx v673. They are 2 outdoor speakers.. please help
I had a similar problem where I could not increase zone 2 volume - Page 100 in the manual notes that 'power amp assign' must be set to "7 Ch + 1 zone" before zone 2 max volume can be changed. Try that.
Jul 08, 2012 | Yamaha RX-V663 Receiver
I have a Yamaha RX V665 and I am unable to change the volume
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jun 07, 2010 | Yamaha RX-V663 Receiver
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
Trying to hook up Zone B stereo speakers in two additional rooms.
The infrared mentioned by the manual is most likely an extension possibility to use the remote control in each room, forget that part.
What you need to do is quite simpel, after connecting all speakers, you should indicate in the setup menu of each zone which speakers are connected and do as follows:
in main room select 5.1 setup, for the other zone select only the left and right front speakers.
Your EXTRA SP indicates the extra speakers for 7.1 setup and when set to zone B it recognises only 1 speaker.
So read carefully the manual how to connect Zone 2 speakers and connect that way, than carefully walk through the setup menu to setup the zone 2 correctly.
Apr 09, 2009 | Yamaha RX-V663 Receiver
Mar 15, 2009 | Yamaha RX-V3800 Receiver
Multiple speakers on zone 2 0r 3 speaker output terminals
barneyluc
Oct 10, 2008 | Yamaha RX-V3800 Receiver
on remote
jeff
Jul 29, 2008 | Yamaha RX-V661 Receiver
No sound from Zone 2/3 speakers
make sure that you are selecting the sp2 to be working with zone 2/3. Be careul and check volume to zone 2/3 on front panel before you activate sp2 with zone2/3.
Jan 20, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V490 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
