Problem with HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply
hp desktop power supply mosfet 23k3548 datasheet or equivalent
i have an hp desktop model : d530s with power supply series pdp124p
inside ,due to electrical problem ,the power supply broke down ,i replaced the fulty parts but i still need 2sk3548 ,i tried 2sk2611 and irfp460 still it didnot work ...
if any body can help me to find the specs to be able to get an equivalent ..... please help.....thanx..
Posted by avatar on Jan 01, 2009
    • By avatarsifiguy2002 Feb 15, 2009
    • thanx aenim4 for your reply ,i already solved my problem i got the part from another faulty power supply ,,and i know its cheap but i got to fix my power supply for only 3$ ,...
      once again thank you for your reply ....
    • By avatarAenim4 May 11, 2010
    • why are you repairing a PSU? it's cheap to buy a new one, it will save you a lot of time and unless you are very good at soldering it will give you better system stability. Furthermore, stock HP's PSUs aren't that good.
Suggested Solution (1)
It sounds that the Power supply Unit is faulty and needs replacement.The ATX powersupply is easy to replace. you can do it yourself. Just remember how you take it out is how you're gonna install a new one back, remember where the connectors go on the mother board. Remove PC from power mains before you work on the PC. Before you touch the inside of the PC just touch the frame of the PC to ground your self to avoid static. Good luck.
  • by Author image Trevor Sauna Over a year ago
Source: HP PC will not turn on.
Was this solution helpful?
No
Yes
Tips for Helping sifiguy2002 With Their Issue
  • Give detailed step-by-step instructions
  • A picture or video is helpful
  • Use plain language not industry jargon
  • Check spelling & punctuation
Hide Tips
Add Your Solution
See all HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply Problems
