Question about HP Officejet 5780 Printer
5780 printer - Align printer process each time you start printer
I was chatting with Arleane when we got disconnected.
    President:
  • 8,637 Answers
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Posted on Jan 27, 2009
Press enter to alline cartridges
If you are getting Alignment failed or Align cartridge Error, It could be because of these possible reasons listed below.
1. Faulty Cartridge ( if you are replacing one now )2. Refilled Cartridge ( not filled properly )3. Cartridge Low on ink ( does not give printer enough ink to align the printer )4. Could also be Hardware Issue ( Most of the time the HP Printer has life time of 4-5 years )
First step,
Remove all the cartridges out and clean the electrical contacts ( golden Contacts ) with a lint free cloth and Re-install them again
It should go through the alignment process and complete it.
If it does not,
Try to access the Setup menu and under tools you will find Align Printer, Try this.
If the Cartridge ink is full or has adequate ink ( atleast 30% in each cartridge ), and the cartridge is not refilled, then the last option is to do a hard reset on the printer.
But Doing the reset your printer will loose network connection, all the printer settings and fax logs,
To do the Reset,
Disconnect the power cord from back of the printer ( while printer is powered on )While holding the # and 6 button at the same time, Connect the power cord back.Go through the setup process to re-setup the printer settings,If it still does not align the printer, You may give a try to install using new cartridge ( but i doubt, it could be the end of the printer.)
Call HP and check if they have any good offer or they can help you with aligning the printer once.
Regards,Suhail
Nov 13, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Difficulty sending faxes, allign cartridges
Have you tried to uninstall the existing driver and reinstall the driver back to check if that works.
Aug 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Align to align your new print cartridge ? problem ?? hp officejet 4212 All-İn-One .
after the printer has printed the alignment shoot, Place is face up on the document feeder and press OK button,
If this does not work, Disconnect power cord from printer ( while printer has power ) and Press and hold # and 6 button and connect the cord back.
Follow the process to align the printer
2nd Solution Is :
Press Menu ( setup ) button on printer
Scroll to Tools ( press ok )
Choose Align Printer/Cartridge ( press ok)
Jun 18, 2010 | HP OfficeJet 4255 All-In-One InkJet...
RE: HP 2110 all-in-one printer. I have put in a new Black HP toner cartridge (color is OK). The printer then goes through the "Align Print Cartridges" process. After the cover page (which prints...
Turn off the printer
Clean the Scanner Glass with Lint Free Cloth ( drop 2-3 drops of water on Cloth, Squeeze it and Wipe the Scanner Glass.
Also try to switch/change the Wallsock/Surge protector socket since the Scanner bulbs are not getting enough power to scan the page
Jun 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
How do I insert printer cartridge
Just push them in horizontally ie. completely straight. You have to push pretty hard - just make sure you don't overdo it - until they go no further.
May 14, 2008 | HP Officejet 5780 Printer
Align page message
I have an OfficeJet 5780 and I have to do the alignment also. The allignment page it prints should have instructions on it. Just put it in the scanner and press "Enter". It needs to scan it to align the print heads.
This is from the manual on their website:
The HP Officejet prompts you to align cartridges every time you install or
replace a print cartridge. Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1 Press Enter on the front panel.
An align cartridges (test pattern) page prints.
2 Load the align cartridges page face down in the ADF between the paperwidth
guides and press the Enter button again.
3 Recycle or discard the page.
Geno
Feb 21, 2008 | HP Officejet 4110 All-In-One InkJet...
Open Questions:
See all HP Officejet 5780 Printer Questions
HP Officejet 5780 Printer Logo
215 people viewed this question
Ben Johnson
