Question about GE Computers & Internet
Tube for icemaker freezes
The tube that the water goes into the ice maker freezes
    Scholar:
  • 108 Answers
From my past experience, you simply need a new water valve on the refrigerator. OR
Be sure the temperature control is not turned up more than the midpoint, or the tube can freeze also.
Too cold means the water line can freeze up quickly.
Hope one of these helps you out!
Posted on Jan 17, 2009
Ice buildup from water feeding the ice maker
Are you certain that the ice build-up is actually originating from the water flow into the icemaker? If ice is built-up on the rear freezer panel, then your problem is more than likely a defrost component issue (defrost thermostat or defrost heater(s). If the ice is built-up on the side wall of the freezer near the icemaker, then water is probably being diverted inside the water inlet tubing that goes into the icemaker. This diversion is usually caused by an accumulation of ice inside the water inlet tubing. You will probably need to remove the icemaker in order to glance inside the water inlet tubing to see if ice is in fact inside the tubing. If so, take a screw driver or other object that won't puncture the tubing and remove the ice.
Contact an appliance service company if the ice is on the rear freezer panel.
Feb 17, 2010 | GE GSH25JFR Side by Side Refrigerator
Water is freezing in the tube feeding into the ice maker. What could be the cause?
Generally the cause is a defective water valve that feeds the icemaker.
The water valve is allowing a small amount of water to leak past the seat. The water then slowly drips down the icemaker fill tube and freezes in the tube causing a blockage of ice to fill the diameter of the fill tube.
Replace the water valve.
Clean or replace the water supply valve that supplies the house water to the water valve on the ref.
This will ensure trouble free ice maker operation.
Jan 16, 2010 | Refrigerators
No water in the ice maker
Pour about 2/3 cup of water into icemaker . If it freezes and dumps , and water doesn't go into icemaker , replace the water inlet valve ( the piece on the refrig that the wall waterline connects to . If it doesn't dump the water poured into it after freezing , then replace the icemaker .
Sep 06, 2009 | Maytag MFD2561HE Bottom Freezer French...
No ice
Pour about 1/2 cup of water into icemaker . If it freezes and dumps , the water valve is bad ( where the wall water line connects to the fridge ) . If it freezes and does not dump and the ice stays in the icemaker , replace the icemaker . Also check the fill tube ( the tube going from the freezer wall to the icemaker itself ) to see if it has frozen closed . If it has , the water valve is not closing completely , and letting a drop thru and freezing in the tube . Also an indication of a bad water valve .
Aug 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
No water coming down tube in kenmore ice maker
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Jan 04, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
I have a whilpool ed22rf fridge the icemaker cycles but no water goes to the icemaker. i have water @ the fridge,dispenser,and @ the valve
hi thanks for the question. A small tube goes in the ice maker it directs the water in the tray .Some times it will freeze up . check that if not frozen the ice maker water valve is the source of the problem thanks the appliance doc
Sep 29, 2008 | Whirlpool Refrigerators
Ice maker isn't filling with water. Water is on and ice maker is on. It's been humid.
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker makes hollow ice! Why?
Not getting enough water into the ice maker. Could be a partially frozen supply line, restricting the total water input, or it could be that the timer needs to be adjust.
If the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
To adjust the timer, follow the instructions here http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Jul 16, 2008 | Amana AFD2535DES French Door Refrigerator
Ice accumulating in freezer
There should be a tube that brings water to your icemaker from the back of the fridge into the icemaker. This tube is frozen with water, or the inlet where this tube feed the icemaker tray is frozen. The result is that water cannot go to the ice maker, and instead, goes over the top of the inlet area.
Verify that this is indeed what is going on.
The fix is to remove the blockage/buildup of ice at the inlet. You may have to detach the icemaker to get to it. Be carefull with electricity! Also be carefull as plastic can break under stress!
The tube may be frozen to the inlet, channel locks can be used to gently twist the tube to break it free.
Good Luck!
Jan 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
Maytag MS2732GRW ice maker quit
guest make sure your wire arm on icemaker is down same dandcs also for orig poster they have duel water valves one goes to door water one goes to icemaker. icemaker works a general rule more than door water so wears out faster but you have to replace both as they are a unit .other things that will stop ice production are frozen ice fill tube ,bad motor module in icemaker .check that first .if that don't solve it then reply to me and we will get deeper
Dec 31, 2007 | Maytag MSD2732GR Side by Side Refrigerator
Computers & Internet Logo
117 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
