Question about Belkin (F5D7230-4) Router (587009)
Reinstalling router Hi, when reinstalling my router, do i need to wire it up to the computer to begin with to configure the settings?
  • 192 Answers
Yes depens if you are using wirless or not.
Posted on Jan 03, 2009
2 Suggested Answers
marked
  • 6487 Answers
SOURCE: Hi, when reinstalling my router,
Yes its really advisable to wire the router and the computer when you try to reconfigure a router so everything will be working fine........
Posted on Jan 01, 2009
Just recently, my internet has gone haywire. My single wired connection works fine, but all my wireless connections have gone down the drain. FF version 5 keeps popping up with "Content encoding...
make sure you are hardwired to the router before configuring, access router by typing 192.168.1.1 on the address bar. then username is admin and the password is the word password itself. all in lower case. click to wireless settings and make sure your not on the advance wireless settings. check the ssid or your network name. and make sure the security is WPA, not WEP. then type your passphrase on the blank box. its a personal password and click apply. it would take about a minute or two to apply the settings and ex out the page after its done. then try to connect your wireless again. dont use a mac computer to configure it....
Jul 18, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I'm trying to connect it to my wireless router and it's not connecting
try reinstalling the wifi driver and if it still doesn't work then update the driver online... else
Run ipconfig /all from a command prompt & post the output....
Mar 11, 2011 | Sylvania G-Netbook
I reinstalled windows XP and now my Linksys wireless router will not connect to the computer. I reset the router. There are three computers on the network. The only one that can/t connect is the one with...
My friend,
In that computer go to the wireless connection in the control panel.
And try to connect through the Windows utility.
Don't forget to start the wireless zero configuration from services.msc
To get in to services.msc in xp
Click on run and type services.msc
Then search for the wireless zero configuration .
Start the service.
Make sure if there is any other utility is there on the computer then disable that.
Dec 17, 2010 | Linksys Wireless-G WRT54G Router
Error 323 Could not access new router
Hi, try resetting the router settings to default using the RESET button at the back. Configure afresh.
Feb 22, 2010 | Computers & Internet
Wi-fi throufh dlink router has worked fine in past on my laptop. Recently the operating system was replaced and it will not connect- message is 'wireless network connection doesn't have a valid IP...
Operating System? Sounds like you might need to reinstall your router. the valid ip configeration issue probably happened because once a router hooks up to the internet it has a set ip address but since the operating system changed your's and your friends computer don't recignize it. If reinstalling the router doesn't work then you should try asking whoever changed the operating system.
Nov 29, 2009 | Computers & Internet
Your experts told me to change the ip address of my router. When I go to IE and type in 192.168.1.1 nothing happens. So I reset the router and tried reinstalling the software. Now on step 10 of...
first reset your router to default setting by using button behind the router in between ethernet prot and anteena using a thin screw driver or pen tip . then its default ip will be 192.168.1.1.
then first connect you pc with router using a straight cable. Set your pc ip of same class eg 192.168.1.2. then try.
Aug 20, 2009 | Linksys Wireless-G WRT54G Router
Slow ping time
Ping depends on the server network and not the configuration of the laptop.If the ping varies, you need to check the network configuration.
Any further help, let me know.
Thanks for using "Fixya".
Jun 17, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Jan 01, 2009 | Belkin (F5D7230-4) Router (587009)
I have a linksys wireless-g broadband router model#wrt54g. this unit was working fine, until today when suddenly it was as if the computer( desktop model DEll dimension 8400 running widows vista ultimate)...
try to plug all the connection as it was before, then you will be able to access your wireless f router via web based control panel and from there you will be able to configure the settings, if its automatic or you have to set as static, it depends on the modem, if the modem requires you to dial up for the connection so that the router may be able to read the connection and you will start to have the internet connection as soon as the modem reads the router through this setting, the web access by default is 192.168.1.1 and the defaul username would be admin and password is admin.
hope thi help you out, if theres anything you need to ask just send me question...
ally
Jul 22, 2008 | Computers & Internet
D-link di-524up configuring router with bigpond
Hello cook_ka
You can find information about and downloads for your "DI-524UP 54 Mbps Wireless Broadband Router Plus Print Server" HERE on D-Link's Australia & New Zealand regional web site.
You can find its product manual HERE. Please, download this manual. (You will need Adobe Acrobat Reader or another PDF file reader in order to open the file.)
In order to access the router and get it configured initially, connect a computer to any one of the router LAN ports (NOT the WAN port) using an Ethernet patch cable.
The instructions for configuring your router begin on page 8 of the product manual.
This router has a configuration wizard as well. Instructions for using the configuration wizard begin on page 10 of the manual.
NOTE-1: The default IP address of your router is 192.168.0.1
NOTE-2: Don't try to access the router wirelessly until you have the router configured and your connection to the Internet working (using a "wired" connection from your computer to the router).
NOTE-3: I assume that, since your ISP is BigPond, that your Internet access connection is ADSL. In that case, you are going to need your ADSL login credentials (primary account user name and password) in order to configure the WAN side of your router settings.
Please, let us know if this information was helpful to you or, of course, if you have any further questions.
BJ
Apr 03, 2008 | Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
