Question about Belkin (F5D7230-4) Router (587009)
Hi, when reinstalling my router, do i need to wire it up to the computer to begin with to configure the settings?
  • Anonymous Jan 02, 2009
    Do I have to use an ethernet cable? I have a laptop which only has 1 ethernet port, do i just wire up the router to the computer or do i need to be connected to the internet via the modem at the same time?
  • Belkin Master
  • 6,487 Answers
Yes its really advisable to wire the router and the computer when you try to reconfigure a router so everything will be working fine........
Posted on Jan 01, 2009
I have been installing the router program step by step but when it comes to searching for the router it does not detect it and it tells me to reinstall it again. What shall I do?
u can follow the instructions and try and uninstall then reinstall but personally i dont use any packaging software i just use a wired connection and setup the router...anyway here is a youtube video u can view to help setup ur router (http://www.youtube.com/watch?v=EKOZvCCZ7_M&playnext=1&list=PL813062982C965CEE).
Jun 11, 2011 | D-Link DIR-615 Wireless Router
Hi, my 2 wire ATT wireless broad band Internet router isn't working. Flashing red lights notes
You need to RESET router then configure it .For that press hold RESET button for 10 seconds then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Sep 04, 2010 | AT&T Computers & Internet
How to set up wep security on a linksys router that was already set up with no password it is a linksys wrt54g on lrouter a dsl network
Hi
Begin setup of your Linksys Wireless Router by first plugging in the power. Give it 10 seconds or so to initialize and then plug an ethernet cable into your wall jack and into the port on the back of the router marked Internet. Next get another ethernet cable and plug one end into your laptop and the other into one of the ports labeled 1-4 on the router. Your computer is now properly connected to the router to begin its setup and configuration.
thanks & rgds
Jul 13, 2010 | Linksys Wireless-G WRT54G Router
Taking forever to configure computer on reinstallation of wrt54g
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 14, 2010 | Linksys Wireless-G WRT54G Router
Error 323 Could not access new router
Hi, try resetting the router settings to default using the RESET button at the back. Configure afresh.
Feb 22, 2010 | Computers & Internet
Need to restart wired computer to connect laptop to wireless router. wired computer is dell e520 using windows vista. router is linksys wrt54g ver 6.Laptop sometimes gets connected by another network, not...
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Nov 27, 2009 | Linksys Wireless-G WRT54G Router
Help set up wireless router
It's better to connect a computer using a cable when configuring a router. establish a wired connection first before running wireless to make sure that the router has been configured.
1. connect your computer to any of the LAN ports of the router
2. Connect your modem to the WAN or Internet port of the router
3. restart your computer
4. Type http://192.168.0.1 in your browser's URL interface.
5. go to connection setting and select the type of connection required by your ISP then save the settings.
Jun 24, 2009 | D-Link DI 514 Wireless Router (DI-514)
Reinstalling router
Yes depens if you are using wirless or not.
Jan 01, 2009 | Belkin (F5D7230-4) Router (587009)
Regarding your response....
Do you have any hard wired computer which is going online..if yes try the following steps
  1. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  2. Click Wireless Settings under Setup menu.you will find your key..
if not connect your laptop directly to the router with a cable and check if you are able to go online..and the try the steps, if not you have to start over from the begining
Jul 29, 2008 | NetGear RangeMax WPN824 Wireless Router...
D-link di-524up configuring router with bigpond
Hello cook_ka
You can find information about and downloads for your "DI-524UP 54 Mbps Wireless Broadband Router Plus Print Server" HERE on D-Link's Australia & New Zealand regional web site.
You can find its product manual HERE. Please, download this manual. (You will need Adobe Acrobat Reader or another PDF file reader in order to open the file.)
In order to access the router and get it configured initially, connect a computer to any one of the router LAN ports (NOT the WAN port) using an Ethernet patch cable.
The instructions for configuring your router begin on page 8 of the product manual.
This router has a configuration wizard as well. Instructions for using the configuration wizard begin on page 10 of the manual.
NOTE-1: The default IP address of your router is 192.168.0.1
NOTE-2: Don't try to access the router wirelessly until you have the router configured and your connection to the Internet working (using a "wired" connection from your computer to the router).
NOTE-3: I assume that, since your ISP is BigPond, that your Internet access connection is ADSL. In that case, you are going to need your ADSL login credentials (primary account user name and password) in order to configure the WAN side of your router settings.
Please, let us know if this information was helpful to you or, of course, if you have any further questions.
BJ
Apr 03, 2008 | Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
