Question about Kenmore 43142 Front Load Washer
Water is pouring out of deteregent tray on fill up
Water is coming out of the detergent tray are on fill -up tray area drains very but very slow
Inside the washing machine there drain from the detergent tray to the washer, it is plugged by a piece of clothing. remove the clothing and all should be fine.
Posted on Feb 08, 2009
Bunn VPR 12-cup pourover is leaking water from the back at the bottom every time I pour water in. It leaks about 1/2 cup or more. Is there a seal or gasket I can replace to remedy this?
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the thank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
May 12, 2017 | Bunn Coffee Makers & Espresso Machines
Bunn coffee maker leaks
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
Aloha, ukeboy57
Jun 17, 2014 | Bunn VPR Coffee Maker
How do I fix my bunn #053213cs from leaking from the bottom
Aloha, ukeboy57
Jun 04, 2014 | Bunn VPR Coffee Maker
Water overfill
The A10 has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
Aloha, ukeboy57
PS. Check your using the correct size decanter for this brewer. If it's a 10 cup brewer then make sure all the decanters in the office is also 10 cup. Pouring a 12 cup pot into brewer will have 12 cups of coffee come out (over flowing the 10 cup pot.) Note that not all decanters are made the same size. Other brands may be different. Test by filling a pot with water (from faucet) then pouring directly into pot in question. It should match and not under fill nor over fill.
Apr 04, 2014 | Bunn A10 Coffee Maker
Water is pouring out of my dispenser drawer
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Water coming out of detergeant tray when filling. water can be removed from machine if drain is selcted manually as a programme
IS MACHINE OVER FILLING OR IS WATER JUST COMMING OVER TRAY IF TRAY TRY CLEANING TRAY AS MAY BE BLOCKED ALSO CHECK WHER TRAY CAME OUT FROM FOR SOAP POWDER DEPOSITS
Jan 01, 2010 | Washing Machines
Leaking from Detergent tray
TAKE THE DETERGENT TRAY OUT AND CLEAN IT.
IF THE PROBLEM PERSISTS TURN THE WATER DOWN TO A DRIBBLE AND SEE IF THIS FIXS THE FAULT. IF IT DOES--- THE WATER IS SPLASHING UP THE FRONT OF THE TRAY AND OVER THE TOP.
1) TAKE THE TRAY OUT 2) LOOKING AT THE TOP OF THE CAVITY ,COUNT BACK 4 ROWS OF HOLES, DRIILL THEM OUT TO 1/4 INCH . 3) BLOCK THE FIRST 3 ROWS OF HOLES WITH SILSATIC.
IF THE SLOW FILL DOES NOT FIX THE PROBLEM TAKE THE 2 SCREWS OUT OF THE BACK AND SLIDE THE TOP OFF, YOU WILL THEN BE ABLE TO SEE THE DISPENSER AND THE HOSES GOING TO IT. THEY MAY BE DAMAGED.
Jul 06, 2009 | LG WM-2277HW Front Load Washer
Miele W830
I have exactly the same problem - what was the answer ?
Mar 15, 2008 | Miele Novotronic Premier 500 Front Load...
Fridge filling with water
There usually is a drain at the back of the fridge it's possible that this is clogged, This drain leads to an evaporation tray usually in the base of the fridge.
Oct 09, 2007 | Kenmore 94499 Refrigerator
Kenmore 43142 Front Load Washer Logo
109 people viewed this question
Sal De
fordexpert
Robert Rankin
